602
602
    TRIPPLITE
    POWER STRIP 7.38"15A 5OUT 6'CORD
602 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Tripp Lite Waber Industrial Power Strip, 5-Outlet, 6 ft. (1.83 m) Cord, Switchless MODEL NUMBER: 602 Highlights ● 5 outlets ● 6-ft. (1.83 m) cord ● 8.6-in. overall length ● No switch Package Includes Description The Waber-by-Tripp Lite 602 Power Strip offers a convenient method of power distribution in workbench, wallmount or floor mount applications. Includes 5 NEMA 5-15R output receptacles with 1.188-inch centerto-center spacing, 6-ft. (1.83 m) AC line cord and keyhole mounting tabs for installation in a wide variety of applications. Corded, multi-outlet strip reduces cable clutter and enables the connection of multiple electrical devices to a single AC wall socket. Unfiltered electrical pass-through makes the 602 ideal for distributing alternate waveform UPS or generator power. Features rugged all-metal housing, 15-amp resettable circuit breaker and attractive blue/gray color scheme. PLUG/OUTLETS - Input: NEMA 5-15P/Output: 5 NEMA 5-15R ELECTRICAL - 120VAC, 50/60Hz, 15A (Requires standard NEMA 5-15R wall receptacle) FORMAT - Corded power distribution strip Features ● Multi-outlet power strip offers convenient power distribution in workbench, wallmount or floor mount applications ● Includes 5 NEMA 5-15R output receptacles with 1.188-inch center-to-center outlet spacing ● Keyhole mounting tabs for installation in a wide variety of applications ● UL1363 (USA), cUL (Canada) ● 15-amp power handling capacity with circuit breaker ● 6-ft. (1.83 m) AC line cord Specifications OVERVIEW UPC Code 037332108937 INPUT Nominal Input Voltage(s) Supported 120V AC 1/3 ● 602 Power Strip ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Recommended Electrical Service 15A 120V Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (5) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Outlet Orientation Single row of 5 Right-Angle Outlets No Outlet Spacing 1.188 in. USER INTERFACE, ALERTS & CONTROLS Switches No power switch PHYSICAL Color Gray Material of Construction Metal Power Cord Color Black Housing Color Blue; Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between keyhole tabs = 127mm; Distance between end tabs = 207.45 Outlets Measurement (Center to Center) 1.18 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 2.00 x 5.30 x 9.80 Shipping Dimensions (hwd / cm) 5.08 x 13.46 x 24.89 Shipping Weight (lbs.) 1.60 Shipping Weight (kg) 0.73 Unit Dimensions (hwd / in.) 1.500 x 8.750 x 2.500 Unit Dimensions (hwd / cm) 18.7 x 6.35 x 3.8 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Outlet Spacing 1.188 in. Mounting Details Includes flanges FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
602
在尝试翻译PDF文档内容时,遇到了服务超时的问题。
我将尝试使用其他方式来为您提供翻译。
物料型号:602 器件简介:工业电源插座,5个插座,6英尺(1.8米)线长,无开关 引脚分配:5个NEMA 5-15R输出插座,中心距1.188英寸 参数特性:支持120V交流电,推荐电气服务为15A 120V,频率兼容性50/60Hz,带有15A可复位断路器 功能详解:提供工作台、壁挂或地面安装的便捷电源分配方式,减少电缆杂乱,适用于多种应用场景 应用信息:适用于需要连接多个电气设备的场合,如工作台、壁挂或地面安装 封装信息:坚固的全金属外壳,蓝色/灰色配色方案,带有安装法兰和安装孔或槽,中心孔距为127mm,端部孔距为207.45mm。
很抱歉,暂时无法提供与“602”相匹配的价格&库存,您可以联系我们找货
