PDU12IEC
PDU12IEC
    TRIPPLITE
    POWER STRIP 16A 14OUT IEC RK MNT
PDU12IEC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.9-3.8kW Single-Phase 120–240V Basic PDU, 14 Outlets (12 C13 & 2 C19), C20 16A Input, 1U Rack-Mount MODEL NUMBER: PDU12IEC Highlights ● C20 inlet accepts wide variety of user-supplied power cords ● 14 total outlets—8 rear C13, 2 rear C19 and 4 front C13 ● Switchless design prevents accidental shutdown ● Reversible all-metal housing ● Installs in rack, on wall or under counter Package Includes Delivers 120–240V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Ideal for networking, telecom, security, audio/video and sound reinforcement applications. Description The PDU12IEC 1.9/3.8kW Single-Phase 120–240V Basic PDU is the perfect no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Perfectly suited for high-density IT environments, the PDU12IEC features a single load bank with 14 total outlets—eight rear C13, two rear C19 and four front C13. The C20 inlet accepts a variety of user-provided power cords that connect to your facility’s compatible AC power source, generator or protected UPS to distribute power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. Dual 16A circuit breakers protect connected equipment from dangerous overloads. The reversible all-metal housing mounts in 1U of space in EIA-standard 19-inch racks, as well as on a wall or workbench or under a counter. With a compatible rack and Tripp Lite’s PDUSIDEBRKT accessory (sold separately), you can adapt the PDU12IEC for vertical 0U rack-mounting. Features Reliable Single-Phase Power Distribution ● Ideal no-frills PDU for networking, telecom, security, audio/video and sound reinforcement applications ● 14 total outlets—8 rear C13, 2 rear C19 and 4 front C13—in one load bank ● Built-in 16A circuit breakers protect outlets against overloads ● C20 inlet accepts wide variety of user-supplied power cords ● Rear-panel grounding lug Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Mounts horizontally in 1U of EIA-standard 19 in. 2- and 4-post racks 1/3 ● PDU12IEC 1.9/3.8kW SinglePhase 120–240V Basic PDU ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Reversible all-metal housing faces front or rear in rack ● Ready for toolless 0U vertical installation with optional PDUSIDEBRKT (sold separately) ● Also mounts on wall, workbench or under a counter Specifications OVERVIEW UPC Code 037332116253 PDU Type Basic INPUT PDU Input Voltage 120; 125; 127; 200; 208; 220; 230; 240 Recommended Electrical Service Single-phase 16/20A 120-240V service Maximum Input Amps 16 Maximum Input Amps Details Agency derated to 16A continuous (North America only) PDU Plug Type IEC-320 C20 Input Phase Single-Phase Input Cord Details C20 inlet accepts user supplied input cable with C19 output connection Input Cord Length (ft.) 0 Input Cord Length (m) 0.00 OUTPUT Output Capacity Details 3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V), 2.03kW (127V), 1.92kW (120V) / 16A total capacity; 16A max per C19 outlet; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (12) C13; (2) C19 Output Nominal Voltage 120-240V Overload Protection 16A circuit breaker USER INTERFACE, ALERTS & CONTROLS Switches No power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount and undercounter installation supported 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Minimum Required Rack Depth (cm) 19.81 Minimum Required Rack Depth (inches) 7.8 Outlets Measurement (Center to Center) Distance between Front (C13) outlets = 28.75mm; Distance between Rear (C19) outlets = 55mm; Distance between Rear (C13) outelts = 28.75mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.10 x 20.60 x 9.30 Shipping Dimensions (hwd / cm) 5.33 x 52.32 x 23.62 Shipping Weight (lbs.) 3.70 Shipping Weight (kg) 1.68 Unit Dimensions (hwd / in.) 1.750 x 19.000 x 4.250 Unit Dimensions (hwd / cm) 4,4 x 44,5 x 10,8 Unit Weight (lbs.) 3.20 Unit Weight (kg) 1.45 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU12IEC 价格&库存
很抱歉,暂时无法提供与“PDU12IEC”相匹配的价格&库存,您可以联系我们找货
