RS-1215
RS-1215
    TRIPPLITE
    POWER STRIP 15A 12OUT 19"RACKMNT
RS-1215 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1U Rack-Mount Power Strip, 120V, 15A, 5-15P, 12 Outlets (6 Front-Facing, 6-Rear-Facing), 15 ft. (4.57 m) Cord MODEL NUMBER: RS-1215 Highlights ● Designed for standard 19-inch racks (1U high) ● 12 outlets (6 front / 6 rear) ● 15-amp circuit breaker ● 15-ft. (4.57 m) cord Package Includes Description Tripp Lite's RS-1215 Power Strip offers 15 amp capacity AC power distribution in a versatile multi-mount cabinet. Detachable mounting flanges are configurable for rackmount, wallmount and under-counter installation. Uses only 1 rack space (1U) when installed in any 19 inch rack meeting EIA standards. Unfiltered electrical pass-through makes RS-1215 ideal for distributing alternate waveform UPS or generator power in rack enclosures, network closets and more. Includes 12 NEMA5-15R outlets (6 front/6 rear), 15-ft. (4.57 m) AC power cord and lighted switch with cover prevents risk of accidental turn-off. PLUG/OUTLETS: Input: NEMA 5-15P Output: 12 NEMA5-15R (6 front & 6 rear) ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires standard NEMA 5-15R wall receptacle) FORMAT: Supports 19 in. rackmount (uses 1 rack space/1U), wallmount, under-counter and more Features ● Versatile all-metal cabinet with detachable mounting flanges allows rackmount, wallmount, undercounter and other creative mounting options ● Uses one rack space (1U) in standard 19 inch rack ("zero U" mounting possible in many racks) ● Unfiltered electrical pass-through reliably distributes alternate waveform AC power from UPS or generator to supported equipment ● 12 NEMA5-15R output receptacles (6 front/6 rear) ● 15-ft. (4.57 m) AC cord NEMA5-15P plug connection ● Lighted power switch confirms power on/off status ● Snap-in switch guard prevents accidental turn off ● 15 amp electrical capacity with circuit breaker ● 120V AC, 50/60Hz electrical compatibility Specifications OVERVIEW 1/3 ● RS-1215 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332011534 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (5) Yes Outlet Orientation 6 front facing / 6 rear facing Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent locking switch cover prevents accidental shutoff PHYSICAL Color Black Material of Construction Metal Power Cord Color Black Form Factors Supported 1U rackmount, wall-mount and undercounter installation supported Included Mounting Accessories Rackmount flanges Mounting Holes or Slots No Outlets Measurement (Center to Center) Distance between Front outlets = 3.28 in.; Distance between Rear outlets = 4.5 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 2.00 x 9.30 x 20.50 Shipping Dimensions (hwd / cm) 5.08 x 23.62 x 52.07 Shipping Weight (lbs.) 5.57 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 2.53 Unit Dimensions (hwd / in.) 1.750 x 17.500 x 4.000 Unit Dimensions (hwd / cm) 4.445 x 44.45 x 11.4 Unit Weight (lbs.) 4.6 Unit Weight (kg) 2.09 FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes TVSS Grounding Back panel nut and bolt grounding lug STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
RS-1215
物料型号: - 型号:RS-1215
器件简介: RS-1215是一款1U机架式电源分配器,提供15A的交流电功率分配,具有多种安装方式,包括机架安装、壁挂安装和台下安装。适用于标准的19英寸机架,符合EIA标准,仅占用1U空间。该电源分配器拥有12个NEMA 5-15R插座(前6个,后6个),15英尺(4.6米)的电源线和带有盖子的照明开关,以防止意外关闭。
引脚分配: - 12个NEMA 5-15R输出插座,其中6个位于前部,6个位于后部。
参数特性: - 输入电压兼容性:120V AC - 推荐电气服务:15A 120V - 频率兼容性:50/60 Hz - 输出功率:1800瓦特 - 电路断路器:15A - 支持的设备形式:1U机架安装、壁挂安装和台下安装 - 颜色:黑色 - 材质:金属 - 电源线颜色:黑色 - 附带安装配件:机架安装法兰
功能详解: RS-1215电源分配器具有以下功能: - 多功能全金属机柜,可拆卸安装法兰,支持多种安装方式。 - 在标准19英寸机架中占用1U空间(在许多机架中可以实现"零U"安装)。 - 未过滤的电气直通,可靠地将UPS或发电机的交流电传输给支持的设备。 - 12个NEMA 5-15R输出插座。 - 15英尺(4.57米)的交流电源线。 - NEMA 5-15P插头连接。 - 带有盖子的照明电源开关,确认电源开关状态。 - 防止意外关闭的快插式开关保护罩。 - 15A电气容量,带断路器。 - 120V AC,50/60Hz的电气兼容性。
应用信息: RS-1215适用于机架式环境、网络设备间等多种场合,用于分配UPS或发电机电源。
RS-1215 价格&库存
很抱歉,暂时无法提供与“RS-1215”相匹配的价格&库存,您可以联系我们找货
RS-1215
库存:50
