RS1215-RA
RS1215-RA
    TRIPPLITE
    PWR STRIP 12OUT R/A 19" RACK MNT
RS1215-RA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1U Rack Mount Power Strip, 120V, 15A, 5-15P, 12 Right-Angled Widely Spaced Outlets, 15 ft. (4.57 m) Cord Highlights ● Outlets placed at right angle to accommodate bulky transformers ● 12 widely spaced outlets (6 front / 6 rear) ● Designed for standard 19-in. racks (1U high) ● 15-ft. (4.57 m) cord ● 15A circuit breaker MODEL NUMBER: RS-1215-RA Package Includes Description Tripp Lite's RS-1215-RA Power Strip offers 15A capacity AC power distribution in a versatile multi-mount cabinet. Detachable mounting flanges are configurable for rackmount, wall mount and under-counter installation. Uses only 1 rack space (1U) when installed in any 19-in. rack meeting EIA standards. Unfiltered electrical pass-through makes RS-1215-RA ideal for distributing alternate waveform UPS or generator power in rack enclosures, network closets and more. Features 12 NEMA 5-15R outlets (6 front/6 rear) placed at a right angle (with ground pin at bottom), 15-ft. (4.57 m) AC power cord and lighted power switch with cover that prevents risk of accidental turn-off. PLUG/OUTLETS: Input: NEMA 5-15P, Output: 12 x NEMA 5-15R (6 front/6 rear) ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires NEMA 5-15R wall receptacle) FORMAT: 19-in. rackmount (uses 1 rack space/1U), wall mount, under-counter and more Features ● Versatile all-metal cabinet with detachable mounting flanges allows rackmount, wallmount, undercounter and other creative mounting options ● Uses one rack space (1U) in standard 19-in. rack ("zero U" mounting possible in many racks) ● Unfiltered electrical pass-through reliably distributes alternate waveform AC power from UPS or generator to supported equipment ● 12 x NEMA5-15R output receptacles (6 front/6 rear) ● 15-ft. (4.57 m) AC cord with NEMA5-15P plug ● Right-angle outlet orientation with ground pin at the bottom ● Lighted power switch confirms power on/off status ● Snap-in switch guard prevents accidental turn off ● 15A electrical capacity with circuit breaker ● 120V AC, 50/60Hz electrical compatibility Specifications 1/3 ● RS-1215-RA 1U Rack Mount Power Bar ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332099402 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (9) Yes Outlet Orientation 6 front-facing / 6 rear-facing, all with ground pin oriented to the bottom (when viewed in 1U rackmount configuration) Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent locking switch cover prevents accidental shutoff PHYSICAL Color Black Material of Construction Metal Power Cord Color Black Form Factors Supported 1U rackmount, wall-mount and undercounter installation supported Housing Color Black Included Mounting Accessories Rackmount flanges Mounting Holes or Slots No Outlets Measurement (Center to Center) Distance between Front outlets = 2.03 in.; Distance between Rear outlets = 2.79 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 9.30 x 2.25 x 20.30 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / cm) 23.62 x 5.72 x 51.56 Shipping Weight (lbs.) 5.32 Shipping Weight (kg) 2.41 Unit Dimensions (hwd / in.) 1.750 x 19.000 x 4.000 Unit Dimensions (hwd / cm) 4.445 x 44.45 x 11.4 Unit Weight (lbs.) 4.6 Unit Weight (kg) 2.09 ENVIRONMENTAL Operating Temperature Range 32 to 113 F (0 to 45 C) FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes TVSS Grounding Back panel nut and bolt grounding lug STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
RS1215-RA 价格&库存
很抱歉,暂时无法提供与“RS1215-RA”相匹配的价格&库存,您可以联系我们找货
