6SP
6SP
    TRIPPLITE
    POWER STRIP 12.5"15A 6OUT 6'CORD
6SP 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Tripp Lite Waber Industrial Power Strip Metal, Lighted Power Switch, 6-Outlet, 6 ft. (1.83 m) Cord MODEL NUMBER: 6SP Highlights ● 6 outlets ● 6-ft. (1.83 m) cord ● 13.7-in. overall length ● Lighted master power switch Package Includes Description The Waber-by-Tripp Lite 6SP Power Strip offers a convenient method of power distribution in workbench, wallmount or floor mount applications. Includes 6 NEMA 5-15R output receptacles with 1.625 inch centerto-center spacing, 6-ft. (1.83 m) AC line cord and keyhole mounting tabs for installation in a wide variety of applications. Corded, multi-outlet strip reduces cable clutter and enables the connection of multiple electrical devices to a single AC wall socket. Unfiltered electrical pass-through makes 6SP ideal for distributing alternate waveform UPS or generator power. Features rugged all-metal housing, lighted power switch, 15A resettable circuit breaker and attractive blue/gray color scheme. PLUG/OUTLETS - Input: NEMA 5-15P/Output: 6 NEMA 5-15R ELECTRICAL - 120V AC, 50/60Hz, 15A (Requires standard NEMA 5-15R wall receptacle) FORMAT - Corded power distribution strip Features ● Multi-outlet power strip offers convenient power distribution in workbench, wallmount or floor mount applications ● Includes 6 NEMA 5-15R output receptacles with 1.625-in. center-to-center outlet spacing ● Lighted power switch ● Keyhole mounting tabs for installation in a wide variety of applications ● UL1363 (USA), cUL (Canada) ● 15A power handling capacity with circuit breaker ● 6-ft. (1.83 m) AC line cord Specifications OVERVIEW UPC Code 037332103383 INPUT 1/3 ● 6SP Power Strip ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 Right-Angle Outlets No Outlet Spacing 1.625 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets PHYSICAL Color Gray Material of Construction Metal Power Cord Color Black Housing Color Blue; Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between keyhole tabs = 261.92mm; Distance between end tabs = 330.17mm Outlets Measurement (Center to Center) 1.62 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 14.50 x 3.60 x 6.10 Shipping Dimensions (hwd / cm) 36.83 x 9.14 x 15.49 Shipping Weight (lbs.) 2.22 Shipping Weight (kg) 1.01 Unit Dimensions (hwd / in.) 1.500 x 13.750 x 2.500 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 31.75 x 6.35 x 3.8 Outlet Spacing 1.625 in. Mounting Details Includes flanges FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
6SP
物料型号:6SP
器件简介:6SP电源分配器提供一种方便的电源分配方法,适用于工作台、壁挂或地面安装应用。
包括六个NEMA 5-15R输出插座,中心距为1.625英寸,六英尺(1.8米)交流电源线和用于安装的钥匙孔安装片。
引脚分配:六个NEMA 5-15R输出插座,插座中心距为1.625英寸。
参数特性: - 每组插座间距:1.625英寸 - 输入电压:120V AC - 推荐的电气服务:15A 120V - 频率兼容性:50/60Hz - 带有15A可复位断路器的电源处理能力 - 电源线长度:6英尺(1.83米)
功能详解: - 多插座电源分配器,方便工作台、壁挂或地面安装的电源分配 - 六英尺(1.83米)交流电源线 - 钥匙孔安装片,用于多种应用的安装 - 无过滤的电力直通,适合分配UPS或发电机电源 - 坚固的全金属外壳,带灯的电源开关,15A可复位断路器和蓝/灰色配色方案
应用信息:适用于需要多个电源插座的工作场所,如工作台、壁挂或地面安装应用,可减少电缆杂乱并允许多个电气设备连接到单个交流墙壁插座。
封装信息: - 颜色:灰色,外壳颜色为蓝色/灰色 - 材料:金属 - 电源线颜色:黑色 - 包括安装法兰 - 带有安装孔或槽,钥匙孔片之间的距离为261.92mm,端片之间的距离为330.17mm - 插座尺寸(中心到中心):1.62英寸 - 插座颜色:黑色 - 运输尺寸(高宽深/英寸):14.50x3.60x6.10 - 运输尺寸(高宽深/厘米):36.83x9.14x15.49 - 运输重量(磅):2.22 - 运输重量(千克):1.01 - 单元尺寸(高宽深/英寸):1.500x13.750x2.500 - 单元尺寸(高宽深/厘米):31.75x6.35x3.8
以上信息基于PDF文档内容进行了中文翻译和解释。
很抱歉,暂时无法提供与“6SP”相匹配的价格&库存,您可以联系我们找货
