1000 Eaton Boulevard
Cleveland, OH 44122
United States
8-Outlet Vertical Power Strip, 120V, 15A, 15 ft.
(4.57 m) Cord, 5-15P, 24 in.
Highlights
Ideal for applications needing
multiple convenience outlets for
powering a variety of electronic
equipment
24-in mountable housing with 8
standard NEMA 5-15R outlets
and a 15-ft. (4.57 m) power cord
Lighted, covered On/Off switch
and 15-amp circuit breaker
Sturdy construction and heavyduty, all-metal housing
MODEL NUMBER: PS2408
Package Includes
The PS2408 power strip provides horizontal or vertical power distribution for rackmount, raceway and
workbench applications in a convenient 24-inch mountable housing.
Description
The PS2408 provides a 15-amp, 120v power strip with 8 standard NEMA 5-15 outlets in a rugged, allmetal, mountable housing. It allows for both vertical and horizontal mounting, making it ideal for a variety
of uses including office, rackmount, workbench, industrial and telecom applications. With a NEMA 5-15P,
15-ft. (4.57 m) power cord, you don't have to install the PS2408 next to outlets you already have; it can be
mounted across the room and deliver reliable service where you need it most. A lighted and covered
On/Off switch helps prevent accidental shut-offs, while a 15-amp circuit breaker guards against dangerous
circuit overloads. Its sturdy all-metal extruded aluminum housing stands up to demanding network,
laboratory or factory environments.
Features
Multi-Outlet Power Distribution
Vertical or Horizontal Moun
Extra Long Power Cord
Premium Safety Features
Heavy-Duty Housing
Specifications
OVERVIEW
UPC Code
037332011442
1/3
PS2408
Mounting hardware
Instruction manual
Cleveland, OH 44122
United States
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
15A 120V
Input Cord Gauge Type
14 gauge; SJT
Voltage Compatibility (VAC)
120
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
15
Right-Angle Plug
No
Input Cord Length (m)
4.57
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Circuit Breaker (amps)
15
Transformer Accommodation
(4) Yes
Right-Angle Outlets
No
Outlet Spacing
2.48 in.
USER INTERFACE, ALERTS & CONTROLS
Switches
Lighted 2 position switch controls power to all outlets
Locking Switch Cover
Transparent on/off switch cover prevents accidental turn-off
PHYSICAL
Color
Silver
Material of Construction
Aluminum
Power Cord Color
Black
Form Factors Supported
Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications
Housing Color
Silver
Included Mounting Accessories
Includes mounting clips
Mounting Holes or Slots
No
Outlets Measurement (Center to
Center)
2.48 in.
Receptacle Color
Black
Shipping Dimensions (hwd / in.)
27.76 x 2.40 x 4.61
Shipping Dimensions (hwd / cm)
70.51 x 6.10 x 11.71
2/3
Cleveland, OH 44122
United States
Shipping Weight (lbs.)
3.25
Shipping Weight (kg)
1.47
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
61 x 3.8 x 3.8
Unit Weight (lbs.)
3.2
Unit Weight (kg)
1.45
Outlet Spacing
2.48 in.
FEATURES & SPECIFICATIONS
Antimicrobial
No
Built-In Circuit Breaker
Yes
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL 1363; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PS2408”相匹配的价格&库存,您可以联系我们找货
