PS6020
PS6020
    TRIPPLITE
    POWER STRIP 60" 15A 20OUT15'CORD
PS6020 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 20-Outlet Vertical Power Strip, 120V, 15A, 15 ft. (4.57 m) Cord, 5-15P, 60 in. Highlights ● 20 outlets ● Convenient and safe covered, on/off switch ● 15-amp circuit breaker ● 15-ft. cord ● 60" length MODEL NUMBER: PS6020 Package Includes Features ● Sturdy all-metal 60 inch corded strip format with 2.795 inch center-to-center outlet spacing ● Included mounting hardware ● Includes 20 NEMA 5-15R output receptacles ● Ideal for horizontal or vertical raceway style power distribution in office, workbench, industrial, networking and telecom applications ● Lighted power switch with locking transparent cover prevents accidental shutoff ● 15 amp electrical capacity with circuit breaker ● 120V AC, 50/60Hz electrical compatibility Specifications OVERVIEW UPC Code 037332011473 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No 1/3 ● PS6020 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (20) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (10) Yes Right-Angle Outlets No Outlet Spacing 2.795 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports horizontal or vertical raceway style power distribution in office, workbench, industrial, networking and telecom applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Outlets Measurement (Center to Center) 2.71 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 3.40 x 2.60 x 64.00 Shipping Dimensions (hwd / cm) 8.64 x 6.60 x 162.56 Shipping Weight (lbs.) 4.90 Shipping Weight (kg) 2.22 Unit Dimensions (hwd / in.) 1.750 x 60.000 x 1.250 Unit Dimensions (hwd / cm) 152.4 x 3.8 x 3.8 Unit Weight (lbs.) 5.0 Unit Weight (kg) 2.27 Outlet Spacing 2.795 in. FEATURES & SPECIFICATIONS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS6020
1. 物料型号: - 型号:PS6020
2. 器件简介: - 这是一个20位垂直电源分配器,具有120V、15A的电压和电流规格,带有15英尺(约4.57米)的电源线和5-15P插头。它具有20个插座,方便且安全,带有覆盖的开关和15安培的电路断路器。
3. 引脚分配: - 输出插座:20个NEMA 5-15R输出插座,中心到中心的间距为2.795英寸。
4. 参数特性: - 电气容量:15安培,带有电路断路器。 - 电压兼容性:120V AC,兼容50/60Hz。 - 开关:带有锁定透明盖的照明2位开关,控制所有插座的电源。
5. 功能详解: - 坚固的全金属60英寸带线型分配器,适用于水平或垂直赛格风格的电源分配,适用于办公室、工作台、工业、网络和电信应用。 - 电源开关带有照明和锁定透明盖,防止意外关闭。
6. 应用信息: - 适用于办公室、工作台、工业、网络和电信应用的电源分配。
7. 封装信息: - 颜色:银色。 - 材质:铝。 - 电源线颜色:黑色。 - 支持形式:支持水平或垂直赛格风格的电源分配。 - 外壳颜色:银色。 - 包含的安装配件:包括安装夹。 - 插座尺寸(中心到中心):2.71英寸。 - 插座颜色:黑色。 - 发货尺寸(高宽深/英寸):3.40x2.60x64.00。 - 发货尺寸(高宽深/厘米):8.64x6.60x162.56。 - 发货重量(磅):4.90。 - 发货重量(千克):2.22。 - 单位尺寸(高宽深/英寸):1.750x60.000x1.250。 - 单位尺寸(高宽深/厘米):152.4x3.8x3.8。 - 单位重量(磅):5.0。 - 单位重量(千克):2.27。
PS6020 价格&库存
很抱歉,暂时无法提供与“PS6020”相匹配的价格&库存,您可以联系我们找货
