SS361220
SS361220
    TRIPPLITE
    POWER STRIP
SS361220 数据手册
12-Outlet Power Strip with Surge Protection, (1015A & 2-20A), 15 ft. (4.57 m) Cord, 1650 Joules, 36 in. length Highlights ● 12-outlet (ten 5-15R & two 515/20R) power strip with a 15-ft. (4.57 m) Cord ● Rated at 2400W, 120V, 20A, featuring a resettable circuit breaker to automatically prevent circuit overloads ● Integral, premium-grade, 1650Joule surge suppressor to protect sensitive electronics against destructive, AC transient surges and line noise ● Easy-to-install, vertical or horizontal mounting with adjustable mounting clamps ● Rocker-style, illuminated power switch with a locking safety cover to prevent accidental turn offs ● Certified to meet UL 1449 3rd Edition and UL 1363 standards MODEL NUMBER: SS361220 Package Includes Easily add extra surge-protected power outlets in computer rooms, equipment racks, raceways, workbenches, repair shops, labs or anywhere that needs to connect many electrical devices simultaneously to a single AC wall outlet. Description Need to power and surge-protect multiple pieces of equipment in close proximity to one another? Tripp Lite's SS361220 power strip with integral AC surge protection is a convenient way to give you many surge-protected power outlets where you need them, when you need them. The SS361220 contains a 15ft. (4.57 m) cord, 10 NEMA 5-15R and 2 NEMA 5-15/20R outlets. Each outlet has a 2.48-in. center-tocenter spacing - wide enough for most transformers or AC adapters. To eliminate need for a separate surge protector that can clutter up your work area, the SS361220 contains a premium-grade surge suppressor rated at 1650 Joules for absorbing even the most severe, high-energy, AC transient surges and EMI/RFI line noise that can damage computers and other sensitive electronics. Encased in a rugged, all-metal housing, the SS361220 comes with adjustable mounting clamps for vertical or horizontal mounting, making it ideal for powering multiple loads in equipment racks, computer rooms, repair shops, workbenches and raceways in a variety of internetworking, telecommunication and audio/video applications. An illuminated, rocker-style power switch with a locking transparent cover prevents accidental turn offs, while a resettable 20-amp circuit breaker guards against dangerous circuit overloads. To match the decor of most professional settings, it has an attractive gray housing with black receptacles. Features Multi-Outlet 120V Power Distribution and Surge Protection for Locations with Limited Free Space ● A 2400W, 120V, 20A, corded, multi-outlet power strip connects multiple electrical devices to a single AC wall socket ● Contains an integral surge protector to eliminate the need for a separate desktop unit that can clutter up your work space ● Saves the time and cost of installing new outlets in un-powered areas ● Ideal for branch circuit power distribution to telecommunications, computers or internetworking equipment in rack enclosures, workbenches, table tops, work stations, offices, factories, repair shops, test stands and engineering labs 12 Convenient Outlets Power All Standard Electrical Equipment ● Consists of 10 NEMA 5-15R and 2 NEMA 5-15/20R, which feature a T-shaped neutral hole to accept 1/4 ● SS361220 Power Strip/Surge Suppressor ● Set of adjustable mounting clips ● Warranty information ● Instruction manual both 5-15P and 5-20P plugs outlets for powering equipment with up to a 20A current rating ● Each outlet is 2.48 inches apart (center to center), allowing enough room for most AC adapters and transformers ● An extra-long, 15-ft. (4.57 m) cord can reach wall outlets mounted in a different area or room from where it draws AC power, putting you in control of getting reliable power where you need it most Premium-Grade, Surge Suppression to Protect Against Destructive Surges and Line Noise ● Contains a premium-grade surge suppressor rated at 1650 Joules that goes well beyond competing surge protectors, giving you an exceptional level of AC transient surge and EMI/RFI line noise protection for computers and other sensitive electronics Adjustable Vertical and Horizontal Mounting Options ● Convenient method of optional horizontal or vertical power distribution ● Its 36-in. length and strip-style form factor fits in the most confined spaces unobtrusively ● Easy-to-install with adjustable mounting clamps Premium Safety Features ● Features an illuminated, rocker-style power switch with a locking, transparent guard to prevent accidental turn offs ● An integral, 20-amp resettable circuit breaker prevents dangerous circuit overloads that can irreversibly damage connected equipment Rugged, Durable Housing ● A rugged, all-metal housing is durably constructed making it a great solution for industrial applications ● An attractive gray housing with stylish black receptacles match the decor of most professional settings Specifications OVERVIEW UPC Code 037332186423 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-20P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No 2/4 OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 2400 Output Receptacles (10) 5-15R; (2) 5-15/20R Circuit Breaker (amps) 20 Outlet Spacing 2.48-in. center-to-center spacing USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) No Switches Combination AC circuit breaker and lighted 2-position power switch controls power to all outlets Locking Switch Cover Transparent locking switch cover SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1650 UL1449 Let Through Rating 500V UL verified EMI / RFI Filtering Yes Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Power Cord Color Black Housing Color Silver Included Mounting Accessories Set of adjustable mounting clamps Mounting Holes or Slots No Receptacle Color Black Shipping Dimensions (hwd / in.) 2.40 x 4.40 x 40.00 Shipping Dimensions (hwd / cm) 6.10 x 11.18 x 101.60 Shipping Weight (lbs.) 4.85 Shipping Weight (kg) 2.20 Unit Dimensions (hwd / in.) 1.250 x 1.620 x 36.000 Unit Dimensions (hwd / cm) 3.18 x 4.11 x 91.44 Unit Weight (lbs.) 3.94 3/4 Unit Weight (kg) 1.79 Outlet Spacing 2.48-in. center-to-center spacing FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
SS361220 价格&库存
很抱歉,暂时无法提供与“SS361220”相匹配的价格&库存,您可以联系我们找货
