TLM626NS
TLM626NS
    TRIPPLITE
    POWER STRIP 6OUT 6'CORD
TLM626NS 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power It! 6-Outlet Safety Power Strip, 6 ft. (1.83 m) Cord & Clip, Safety Covers MODEL NUMBER: TLM626NS Highlights ● 6 outlets (including transformer outlets and 4 safety covers) ● 6-ft. (1.83 m) cord ● Rugged metal case Package Includes Description This Tripp Lite power strip is designed to safely distribute power to connected equipment in harsh environments. It provides a convenient source for multiple outlets wherever they're needed. 6 outlets distribute AC power to a wide range of power tools, pumps, air compressors and more. Convenient transformer outlets accommodate multiple transformers without blocking other outlets. A 6-ft. (1.83 m) grounded cord with integrated cord clip reaches distant outlets. A lighted on/off switch with integrated circuit breaker provides power control over connected equipment. Breaker protects against dangerous system overload. 4 safety covers shield unused outlets from debris and accidental contact. A rugged metal case stands up to the harshest environments. Integrated keyhole slots on bottom panel provide convenient wall/desk mounting. Its bright yellow color alerts you and others that power cords and tools are in use. Features ● 6 outlets distribute AC power to a wide range of power tools, pumps, air compressors and more. ● Convenient transformer outlets ● A 6-ft. (1.83 m) grounded cord with integrated cord clip reaches distant outlets. ● A lighted on/off switch with integrated circuit breaker provides power control over connected equipment. Breaker protects against dangerous system overload. ● 4 safety covers shield unused outlets from debris and accidental contact. ● A rugged metal case stands up to the harshest environments. ● Integrated keyhole slots on bottom panel provide convenient wall/desk mounting ● Its bright yellow color alerts you and others that power cords and tools are in use. ● OSHA color guidelines, outlined in Document 1910.145, alert users to hazardous situations, which may cause minor or moderate injury. This Tripp Lite product complies with those guidelines. Specifications OVERVIEW 1/3 ● TLM626NS Safety Power Strip ● 4 safety covers ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332140173 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection Combo power switch and circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row Right-Angle Outlets Yes Outlet Safety Covers Detail Includes 4 outlet safety covers PHYSICAL Color Yellow; Black Material of Construction Metal Power Cord Color Yellow Housing Color Yellow; Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 225mm Outlets Measurement (Center to Center) Distance between standard outlets = 1.19 in.; Distance between standard and transformer outlets = 1.77 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 13.70 x 2.00 x 4.70 Shipping Dimensions (hwd / cm) 34.80 x 5.08 x 11.94 Shipping Weight (lbs.) 1.74 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 0.79 Unit Dimensions (hwd / in.) 12.230 x 2.300 x 1.280 Unit Dimensions (hwd / cm) 31.06 x 5.84 x 3.25 Unit Weight (lbs.) 1.34 Unit Weight (kg) 0.61 FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
TLM626NS 价格&库存
很抱歉,暂时无法提供与“TLM626NS”相匹配的价格&库存,您可以联系我们找货
