1000 Eaton Boulevard
Cleveland, OH 44122
United States
Isobar 8-Outlet Surge Protector, 25 ft. Cord with
Right-Angle Plug, 3840 Joules, Diagnostic LEDs,
Metal Housing
MODEL NUMBER: ISOBAR825ULTRA
Highlights
8 NEMA 5-15R outlets in
exclusive isolated filter banks
Network-grade 3840-joule surge
protection rating
Durable metal housing designed
for tough environments
12A resettable circuit breaker
prevents dangerous overloads
25 ft. AC power cord with rightangle NEMA 5-15P plug
Package Includes
Premium protection for A/V components, network hardware, retail displays, appliances, power tools and
other expensive electronics against dangerous surges, spikes and line noise in home, office and industrial
environments.
Description
Premium protection for essential network workstations, telecom systems, point-of-sale equipment and
audio/video systems, the ISOBAR825ULTRA Isobar® 8-Outlet Surge Protector features a network-grade
surge protection rating of 3840 joules to defend your sensitive electronics against even the strongest
surges and spikes. In fact, Tripp Lite will repair or replace any connected equipment damaged by surges
up to $50,000 for life (valid in the U.S., Canada and Puerto Rico only).
The ISOBAR825ULTRA features eight widely spaced NEMA 5-15R outlets, which are arranged in four
exclusive isolated filter banks that prevent equipment connected to one bank from interacting with
equipment connected to another. These internal barriers also prevent disruptive line noise from causing
A/V distortion, computer lock-ups, data errors and similar problems. Large toroidal chokes, ferrite rod-core
inductors, HF/VHF capacitors and multiple layers of metal oxide varistors remove EMI/RFI interference
and prevent system crashes, reboots and performance problems.
Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the
ISOBAR825ULTRA protects all three, covering two protection modes: full normal mode (H-N) and
common mode (N-G/H-G).
Included safety covers protect against dust while blocking accidental contact with unused outlets. An
integrated 12A circuit breaker protects all outlets and shuts down connected equipment in the event of an
overload. A lighted on/off switch provides one-touch control over connected components. Diagnostic LEDs
show power, protection and line fault status at a glance. An extra-long 25-foot (7.6-meter) cord with rightangle 5-15P plug reaches distant outlets and allows furniture to placed flush against the wall.
Features
Network-Grade 3840-Joule Surge Protection for Home or Office ElectronicsProtects your A/V
components, network hardware, retail displays, appliances, power tools and other expensive electronics
against even the strongest surges and spikesRecommended for network workstations, telecom systems,
point-of-sale equipment and audio/video systems requiring AC line protectionFull normal mode (H-N) and
common mode (N-G/H-G) line surge suppressionExceeds IEEE 587 Category A and B surge suppression
specifications
8 Outlets Accept Wide Range of Electronic Devices8 NEMA 5-15R AC outlets accept most computer,
networking and telecom equipmentOutlets accommodate up to 4 bulky transformers without blocking
other outletsIncluded safety covers block accidental contact with unused outlets
1/4
ISOBAR825ULTRA Isobar 8Outlet Surge Protector, 25 ft.
Cord, Metal Housing
(4) Outlet safety covers
Owner's manual
Cleveland, OH 44122
United States
Isolated Filter Banks Provide Extra ProtectionOutlets arranged in 4 exclusive isolated filter banks to
limit noise interaction among connected equipmentBlocks disruptive EMI/RFI line noise up to 80 dB that
can cause equipment damage or data lossCombine large toroidal chokes, ferrite rod-core inductors,
HF/VHF capacitors and metal oxide varistors to block interference
Premium Safety FeaturesLighted on/off switch provides one-touch control over connected
equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated,
preventing equipment damage and indicating replacement is requiredDiagnostic LEDs confirm power,
protection and line fault status at a glanceConforms to current UL 1449 3rd Edition safety standards
Fits Effortlessly Into Your WorkstationExtra-long 25 ft. AC power cord reaches distant outletsSpacesaving right-angle NEMA 5-15P plug allows furniture and equipment to move flush against the
wallKeyhole slots on bottom panel provide convenient wall or desk mounting optionsAll-metal housing
designed for long life
Backed by Tripp Lite's Ultimate Lifetime Insurance$50,000 Ultimate Lifetime Insurance covers any
connected components damaged by power surge (U.S., Canada and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332138286
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Cord Gauge Type
14 gauge; SJT
Input Cord Gauge (AWG)
14
Voltage Compatibility (VAC)
120
Maximum Surge Amps
150000
Input Plug Type
NEMA 5-15P
Input Cord Details
SJT
Input Cord Length (ft.)
25
Right-Angle Plug
Yes
Input Cord Length (m)
7.62
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Circuit Breaker (amps)
12
Transformer Accommodation
(4) Yes
Right-Angle Outlets
No
2/4
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Switches
Combination AC circuit breaker and two position red illuminated on/off power switch
Diagnostic LED Details
PROTECTION PRESENT (green), LINE FAULT (red) and LINE OK (green)
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
3840
AC Suppression Response Time
NM = 0 ns. CM =
很抱歉,暂时无法提供与“ISOBAR825ULTRA”相匹配的价格&库存,您可以联系我们找货
