PDU1215
PDU1215
    TRIPPLITE
    POWER STRIP 15A 13 OUT RACK M
PDU1215 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.8kW Single-Phase 120V Basic PDU, 13 NEMA 515R Outlets, NEMA 5-15P Input, 15 ft. (4.57 m) Cord, 1U Rack-Mount MODEL NUMBER: PDU1215 Highlights ● NEMA 5-15P input with 15-ft. (4.57 m) cord ● 13 NEMA 5-15R outlets—12 rear and 1 front ● Switchless design prevents accidental shutdown ● Reversible all-metal housing ● Installs in rack, on wall or under counter Package Includes Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Ideal for networking, telecom, security, audio/video and sound reinforcement applications. Description The PDU1215 1.8kW Single-Phase 120V Basic PDU is the perfect no-frills unit for networking, telecom, security, audio/video and sound reinforcement applications. Perfectly suited for high-density IT environments, the PDU1215 features a single breakered load bank with 13 NEMA 5-15R outlets—12 in the rear and one in front. The NEMA 5-15P input plug with long 15-ft. (4.57 m) cord connects to your facility's compatible AC power source, generator or protected UPS to distribute power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. A 15A circuit breaker protects connected equipment from dangerous overloads. The reversible all-metal housing mounts in 1U of space in EIA-standard 19-inch racks, as well as on a wall or workbench or under a counter. With a compatible rack and Tripp Lite's PDUSIDEBRKT accessory (sold separately), you can adapt the PDU1215 for vertical 0U rack-mounting. Features Reliable Single-Phase Power Distribution ● Ideal no-frills PDU for networking, telecom, security, audio/video and sound reinforcement applications ● 13 NEMA 5-15R outlets in one breakered load bank ● 15A circuit breaker protects outlets against overloads ● NEMA 5-15P input plug with 15-ft. (4.57 m) cord ● Rear-panel grounding lug Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Mounts horizontally in 1U of EIA-standard 19 in. 2- and 4-post racks 1/3 ● PDU1215 1.8kW Single-Phase 120V Basic PDU ● Mounting hardware ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Reversible all-metal housing faces front or rear in rack ● Ready for toolless 0U vertical installation with optional PDUSIDEBRKT (sold separately) ● Also mounts on wall, workbench or under a counter Specifications OVERVIEW UPC Code 037332116727 PDU Type Basic INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 15A 120V service Maximum Input Amps 15 PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 1.8kW (120V) / 15A total capacity; 12A max per 5-15R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (13) 5-15R Output Nominal Voltage 120V Overload Protection 15A breaker USER INTERFACE, ALERTS & CONTROLS Switches No power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount and undercounter installation supported Minimum Required Rack Depth (cm) 19.05 Minimum Required Rack Depth (inches) 7.5 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Outlets Measurement (Center to Center) 30.2mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.20 x 20.40 x 9.30 Shipping Dimensions (hwd / cm) 5.59 x 51.82 x 23.62 Shipping Weight (lbs.) 5.27 Shipping Weight (kg) 2.39 Unit Dimensions (hwd / in.) 2.000 x 20.000 x 4.500 Unit Dimensions (hwd / cm) 4.44 x 44.5 x 11.4 Unit Weight (lbs.) 4.9 Unit Weight (kg) 2.22 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); CAN/CSA-22.2 No. 308-14 (Canada); NOM (Mexico); UL 1363 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDU1215
物料型号: - 型号编号:PDU1215
器件简介: - PDU1215是一款1.8kW单相120V基础型PDU,具备13个NEMA 515R插座,NEMA 5-15P输入,15英尺(4.57米)电源线,1U机架式安装。
引脚分配: - 13个NEMA 5-15R插座:12个位于后方,1个位于前方。
参数特性: - 输入电压:120V - 推荐电气服务:单相15A 120V服务 - 最大输入电流:15A - 输出容量:1.8kW(120V)/15A总容量;每个5-15R插座最大12A - 频率兼容性:50/60Hz - 过载保护:15A断路器
功能详解: - 提供120V单相交流电至多个负载,适用于高密度IT环境,如网络、电信、安全、音视频和音响增强应用。 - 无开关设计,防止意外关机。 - 15A电路断路器保护连接设备免受过载危险。 - 可逆全金属外壳,可安装在机架、墙面或工作台或柜台下。
应用信息: - 适用于网络、电信、安全、音视频和音响增强应用。
封装信息: - 材料:金属 - 机架高度:1U - 支持的安装形式:1U机架安装、0U垂直机架安装、墙面安装和柜台下安装 - 最小所需机架深度:19.05厘米(7.5英寸) - 插座测量(中心到中心):30.2毫米 - PDU形式因素:水平(1U) - 发货尺寸:高2.20英寸x宽20.40英寸x深9.30英寸(高5.59厘米x宽51.82厘米x深23.62厘米) - 发货重量:5.27磅(2.39千克)
PDU1215 价格&库存
很抱歉,暂时无法提供与“PDU1215”相匹配的价格&库存,您可以联系我们找货
