EPS-4186
Datasheet revision 1.0
www.chipquik.com
48” Metal Power Strip with 18 Outlets, Surge Protected
Specifications
Power Strip Measurement:
L48" x W1.653" x H1.496" (1219 x 42 x 38mm)*
Outlets:
18
Outlet Color:
White
Outlet Orientation:
Horizontal
Plug / Receptacle Type:
NEMA 5-15P / 5-15R
Outlet Spacing:
3.74" / 1.89" (95mm / 48mm) (center to center)
Power Cord:
6' (1.83m) 14/3 AWG, SJT Heavy Duty
Voltage Input/Output:
110-125V 60Hz
Current Input:
15A
Full Load:
1875VA
On/Off Switch:
Yes (lighted)
Circuit Breaker:
Resettable (built in the switch)
Surge Protection:
Up to 400 Joules
Lines Protected:
(L-N) (L-G) (N-G)
Response time:
Less than 5 nanosecond
Noise Filter:
EMI/RFI
Mounting on Back:
Yes
Mounting Tabs:
On both ends (5/8")
Mounting Clips:
3/4" (19mm) Spring Steel Clips included
Indicator:
N/A
Notes
* Measurement is approximate. For installation purposes: The length of the power strip does not include the mounting tabs
(approx. 0.624"/15.8mm on both ends), if any; the width does not include the size of screws (min. 0.064"/1.6mm on each
side); the height does not include the receptacles (about 0.208"/5.3mm above the surface of the strip).
For use in countries and regions with 110-125V 60Hz only. Not intended for use in or around wet or potentially wet areas.
1
© 1994-2015 Chip Quik® Inc.
很抱歉,暂时无法提供与“EPS-4186”相匹配的价格&库存,您可以联系我们找货
