PDUH20DV
PDUH20DV
    TRIPPLITE
    PDUBASICDUALVOLTC19
PDUH20DV 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.6-3.8kW Single-Phase 100-240V Basic PDU, 14 Outlets (12 C13 & 2 C19), C20 with L6-20P Adapter, 12 ft. (3.66 m) Cord, 1U Rack-Mount Highlights ● C20 input with detachable 12-ft. (3.66 m) cord and L6-20P adapter ● 14 total outlets—12 C13 and 2 C19 ● Switchless design prevents accidental shutdown ● Reversible all-metal housing ● Installs in rack, on wall or under counter MODEL NUMBER: PDUH20DV Package Includes Versatile 16A 100–240V PDU is compatible with wide range of voltages to deliver single-phase AC power to multiple loads from a utility outlet, generator or UPS system. Ideal for data centers, server rooms and network wiring closets. Description The PDUH20DV 1.6-3.8kW Single-Phase 100-240V Basic PDU is a versatile no-frills unit for data centers, server rooms and network wiring closets. Perfectly suited for high-density IT environments, the PDUH20DV features 14 total outlets—four C13 in front and eight C13 and two C19 in the rear. The C20 input plug with detachable 12-ft. (3.66 m) cord connects to your facility's compatible AC power source, generator or protected UPS to distribute power to connected equipment. A NEMA L6-20P adapter is included for 208/240V power environments. The C20 inlet accepts any country-specific power cord with a C19 connector. The switchless design prevents an accidental shutdown, which could lead to costly downtime. The reversible all-metal housing supports a variety of mounting options, including 1U horizontal or 0U vertical mounting in EIA-standard 19-inch racks, under a counter or on a wall or workbench. Features Reliable Single-Phase 16A 100-240V Power Distribution ● Versatile no-frills PDU for data centers, server rooms and network wiring closets ● 14 total outlets—4 C13 in front, 8 C13 and 2 C19 in rear ● C20 input with detachable 12-ft. (3.66 m) cord and NEMA L6-20P adapter ● Inlet accepts any country-specific power cord with C19 connector ● Rear-panel grounding lug Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● Reversible all-metal housing faces front or rear in rack ● Supports 1U horizontal or 0U vertical mounting in EIA-standard 19 in. racks 1/3 ● PDUH20DV 1.6–3.8kW SinglePhase 100–240V Basic PDU ● Detachable C19-to-C20 power cord ● NEMA L6-20P plug adapter ● Mounting brackets ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Also mounts on wall, workbench or under a counter Specifications OVERVIEW UPC Code 037332158963 PDU Type Basic INPUT PDU Input Voltage 100; 120; 125; 127; 200; 208; 220; 230; 240 Recommended Electrical Service Single-phase 16/20A 100-240V service Maximum Input Amps 16 Maximum Input Amps Details Agency de-rated to 16A continuous Input Connection Type C20 inlet accepts included C19-C20 cable with L6-20P adapter PDU Plug Type NEMA L6-20P; IEC-320 C20 Input Phase Single-Phase Input Cord Details Input cable is detachable PDU C20 inlet Input Cord Length (ft.) 12 Input Cord Length (m) 3.66 OUTPUT Output Capacity (kW) 3840 Output Capacity Details 3.84kW (240V), 3.68kW (230V), 3.52kW (220V), 3.33kW (208V), 3.2kW (200V), 2.03kW (127V), 1.92kW (120V), 1.6kW (100V) / 16A total capacity; 16A max per C19 outlet; 12A (10A CE) max per C13 outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (12) C13; (2) C19 Output Nominal Voltage 100-240V SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 17.27 Minimum Required Rack Depth (inches) 6.8 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Outlets Measurement (Center to Center) Distance between front (C13) outlets = 28.75mm; Distance between rear (C19) outlets = 55mm; Distance between rear (C13) outlets = 28.75mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.25 x 10.90 x 20.10 Shipping Dimensions (hwd / cm) 5.72 x 27.69 x 51.05 Shipping Weight (lbs.) 5.50 Shipping Weight (kg) 2.49 Unit Dimensions (hwd / in.) 1.750 x 17.250 x 3.750 Unit Dimensions (hwd / cm) 4,45 x 43,8 x 9,5 Unit Weight (lbs.) 3.75 Unit Weight (kg) 1.70 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Grounding lug STANDARDS & COMPLIANCE Product Certifications IEC 62368-1; CAN/CSA-C22.2 No. 62368-1 (Canada); NOM (Mexico); UL 62368-1 Product Compliance RoHS; FCC Part 15 Class A (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUH20DV 价格&库存
很抱歉,暂时无法提供与“PDUH20DV”相匹配的价格&库存,您可以联系我们找货
