TLM609NS
TLM609NS
    TRIPPLITE
    POWER STRIP 6OUT 9'CORD
TLM609NS 数据手册
Power It! 6-Outlet Safety Power Strip, 9 ft. (2.74 m) Cord & Clip, Hang Holes, Safety Covers MODEL NUMBER: TLM609NS Highlights ● 6 outlets (including transformer outlets and 4 safety covers) ● 9-ft. (2.74 m) cord ● Cord wrap with hang holes ● Rugged metal case Package Includes Description This Tripp Lite power strip is designed to safely distribute power to connected equipment in harsh environments. It provides a convenient source for multiple outlets wherever they're needed. 6 outlets distribute AC power to a wide range of power tools, pumps, air compressors and more. Convenient transformer outlets accommodate multiple transformers without blocking other outlets. A 9-ft. (2.74 m) grounded cord with integrated cord clip reaches distant outlets. A lighted on/off switch with integrated circuit breaker provides power control over connected equipment. Breaker protects against dangerous system overload. 4 safety covers shield unused outlets from debris and accidental contact. A rugged metal case stands up to the harshest environments. Built-in cord wrap with hang holes provides convenient cord management. Integrated keyhole slots on bottom panel provide convenient wall/desk mounting. Its bright yellow color alerts you and others that power cords and tools are in use. Features ● 6 outlets distribute AC power to a wide range of power tools, pumps, air compressors and more. ● Convenient transformer outlets ● A 9-ft. (2.74 m) grounded cord with integrated cord clip reaches distant outlets. ● A lighted on/off switch with integrated circuit breaker provides power control over connected equipment. Breaker protects against dangerous system overload. ● 4 safety covers shield unused outlets from debris and accidental contact. ● A rugged metal case stands up to the harshest environments. ● Built-in cord wrap with hang holes provides convenient cord management. ● Integrated keyhole slots on bottom panel provide convenient wall/desk mounting ● Its bright yellow color alerts you and others that power cords and tools are in use. ● OSHA color guidelines, outlined in Document 1910.145, alert users to hazardous situations, which may cause minor or moderate injury. This Tripp Lite product complies with those guidelines. Specifications OVERVIEW 1/3 ● TLM609NS Safety Power Strip ● 4 safety covers ● Owner's manual UPC Code 037332140166 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V, 15A Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 9 Input Cord Length (m) 2.74 Integrated Cord Clip Yes OUTPUT Frequency Compatibility 60 Hz Output (Watts) 1800 Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection Combo power switch and circuit breaker Transformer Accommodation (4) Yes Outlet Orientation Single row Right-Angle Outlets Yes Outlet Safety Covers Detail Includes 4 outlet safety covers PHYSICAL Material of Construction Metal Color Yellow; Black Power Cord Color Yellow Housing Color Yellow; Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 209.55mm Outlets Measurement (Center to Center) Distance between standard outlets = 30.40mm; Distance between standard and transformer outlets = 45mm Receptacle Color Black Shipping Dimensions (hwd / cm) 40.39 x 6.10 x 17.78 Shipping Dimensions (hwd / in.) 15.90 x 2.40 x 7.00 Shipping Weight (kg) 1.36 2/3 Shipping Weight (lbs.) 3.00 Unit Dimensions (hwd / in.) 15.97 x 3.07 x 1.61 Unit Dimensions (hwd / cm) 40.56 x 7.80 x 4.09 Unit Weight (lbs.) 3.24 Unit Weight (kg) 1.47 FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
TLM609NS 价格&库存
很抱歉,暂时无法提供与“TLM609NS”相匹配的价格&库存,您可以联系我们找货
