6SPDX-15
6SPDX-15
    TRIPPLITE
    POWER STRIP 12.5"15A 6OUT15'CORD
6SPDX-15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Tripp Lite Waber Industrial Power Strip, 6-Outlet, 15 ft. (4.57 m) Cord MODEL NUMBER: 6SPDX-15 Highlights ● 6 outlets ● 15-ft. (4.57 m) cord ● 12.5-in. length ● Lighted master switch ● All-metal housing Package Includes Description Tripp Lite's 6SPDX-15 Power Strip offers a convenient method of power distribution in workbench, wallmount or floor mount applications. Includes 6 NEMA 5-15R output receptacles with 1.505-in. centerto-center spacing, 15-ft. (4.57 m) AC line cord and keyhole mounting tabs for installation in a wide variety of applications. Corded, multi-outlet strip reduces cabling clutter and enables the connection of multiple electrical devices to a single AC wall socket. Unfiltered electrical pass-through makes the 6SPDX-15 ideal for distributing alternate waveform UPS or generator power. Features rugged metal housing, lighted power switch with integrated 15A resettable circuit breaker and attractive beige color scheme. PLUG/OUTLETS - Input: NEMA 5-15P/Output: 6 NEMA 5-15R ELECTRICAL - 120VAC, 50/60Hz, 15A (Requires standard NEMA 5-15R wall receptacle) FORMAT - Corded power distribution strip Features ● Multi-outlet power strip offers convenient power distribution in workbench, wallmount or floor mount applications ● Includes 6 NEMA 5-15R output receptacles with 1.505-in. center-to-center spacing ● Lighted combination power switch with integrated circuit breaker ● Keyhole mounting tabs for installation in a wide variety of applications ● UL1363 (USA), cUL (Canada) ● 15A power handling capacity ● 15-ft. (4.57 m) AC line cord Specifications OVERVIEW UPC Code 037332108074 INPUT 1/3 ● 6SPDX-15 Power Strip ● Warranty information ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 Right-Angle Outlets No Outlet Spacing 1.505 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted combination switch / circuit breaker PHYSICAL Color Beige Material of Construction Metal Power Cord Color Beige Housing Color Beige Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 203.2mm Outlets Measurement (Center to Center) 3.05 in. Receptacle Color Beige Shipping Dimensions (hwd / in.) 2.00 x 5.80 x 14.40 Shipping Dimensions (hwd / cm) 5.08 x 14.73 x 36.58 Shipping Weight (lbs.) 3.10 Shipping Weight (kg) 1.41 Unit Dimensions (hwd / in.) 1.500 x 13.750 x 2.500 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 31.75 x 6.35 x 3.8 Outlet Spacing 1.505 in. FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
6SPDX-15
1. 物料型号 - 型号:6SPDX-15
2. 器件简介 - 6SPDX-15电源分配器提供了一种方便的电源分配方法,在工作台、壁挂或地面安装应用中。包括六个NEMA 5-15R输出插座,间距为1.5英寸,15英尺(4.6米)交流电源线以及用于多种应用安装的钥匙孔安装标签。
3. 引脚分配 - 输出插座:(6)5-15R - 插座间距:1.505英寸
4. 参数特性 - 输入电压兼容性(VAC):120 - 输入插头类型:NEMA 5-15P - 输入电源线长度(英尺):15 - 输入电源线长度(米):4.57 - 输出功率(瓦特):1800 - 电路断路器(安培):15 - 频率兼容性:50/60Hz - 变压器容纳:(2)是 - 插座方向:单排6个 - 直角插座:否
5. 功能详解 - 多插座电源分配器提供了工作台、壁挂或地面安装的便捷电源分配。 - 包括6个NEMA 5-15R输出插座,间距为1.505英寸。 - 集成电路断路器的带灯组合开关。 - 用于多种应用安装的钥匙孔安装标签。 - 额定功率处理能力为15A。 - 15英尺(4.57米)交流电源线。
6. 应用信息 - 适用于工作台、壁挂或地面安装等多种应用。
7. 封装信息 - 颜色:米色 - 材料:金属 - 电源线颜色:米色 - 外壳颜色:米色 - 安装孔或槽:是 - 槽或孔安装测量(中心到中心):203.2毫米 - 插座测量(中心到中心):3.05英寸 - 插座颜色:米色 - 发货尺寸(高宽深/英寸):2.00x5.80x14.40 - 发货尺寸(高宽深/厘米):5.08x14.73x36.58 - 发货重量(磅):3.10 - 发货重量(千克):1.41 - 单位尺寸(高宽深/英寸):1.500x13.750x2.500 - 单位尺寸(高宽深/厘米):31.75x6.35x3.8
6SPDX-15 价格&库存
很抱歉,暂时无法提供与“6SPDX-15”相匹配的价格&库存,您可以联系我们找货
