PS-415-HGULTRA
PS-415-HGULTRA
    TRIPPLITE
    POWER STRIP 15A 4OUT 15'CORD
PS-415-HGULTRA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power strips used within a patient care vicinity may be permanently attached so that it can only be Highlights removed with a tool. Choose the PSCLAMP for a safe and secure mounting solution. ● Safe-IT UL 60601-1 Medical-Grade Power Strip for Patient-Care Vicinity, 4 15A Hospital-Grade Outlets, Safety Covers, 15 ft. Cord Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew ● Approved for standalone use in all patient-care vicinities ● Complies with UL 60601-1 and UL 60950-1 specifications ● Complies with NFPA 99 specifications ● Patented protection circuit guards against shock hazards ● 4 NEMA 5-15R-HG hospitalgrade outlets with locking safety covers MODEL NUMBER: PS-415-HGULTRA Package Includes Full 60601-1 compliance, integrated locking safety covers and a 15 ft. cord make this medical-grade power strip ideal for all areas inside and outside of patient care vicinities. Description The PS-415-HGULTRA Medical-Grade Power Strip -- patent # 7,375,939 -- is the first power strip with full 60601-1 compliance and agency listing, making it ideal for standalone use in all patient care vicinities. This 120V, 50/60 Hz power strip features a NEMA 5-15P-HG hospital-grade plug and four NEMA 5-15RHG hospital-grade outlets that include integrated locking safety covers. A patented protection circuit guards against shock hazards by preventing power from reaching the unit’s outlets in the presence of a fault. The protection circuit automatically resets itself and restores power once the fault threat is gone. The power strip is protected by a antimicrobial powder coating. Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew. The coating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products. Mounting tabs and flanges let you install the PS-415-HGULTRA on a wide variety of surfaces. The allmetal housing ensures safety and is guaranteed to last a long time in demanding environments. With a switchless design that prevents accidental shutoff and a 15-foot (4.57 m) power cord that can reach a distant power source, the PS-415-HGULTRA is a recommended replacement for all noncompliant power strips. Features Power Distribution Anywhere in Any Medical FacilityIdeal for standalone use in patient-care vicinities, therapy rooms, imaging environments and administrative areasPatented protection circuit guards against shock hazards with automatic site fault protectionCircuit breaker resets itself once fault threat is gone120V, 50/60 Hz power strip complies with UL 60601-1 and UL 60950-1 specificationsPatent # 7,375,939 Exclusive Antimicrobial ProtectionAntimicrobial coating helps resist the growth of bacteria, viruses, fungi, mold and mildewCoating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products. Versatile Medical-Grade Solution4 NEMA 5-15R-HG hospital-grade outlets provide consistent power15ft. (4.57 m) power cord provides ample reach to the power sourceRugged all-metal housing for long life in 1/4 ● PS-415-HGULTRA UL 60601-1 Medical-Grade Power Strip ● Owner’s manual with maintenance requirements 1000 Eaton Boulevard Cleveland, OH 44122 United States demanding environments Premium Safety FeaturesIntegrated locking outlet safety covers block access to unused outletsBuilt-in 15A circuit breaker protects against dangerous overloadsSwitchless design prevents accidental shut-off Ready to Use Right Out of the BoxBuilt-in mounting tabs and flanges for easy installation on a variety of surfaces Specifications OVERVIEW UPC Code 037332128430 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Plug Features Hospital Grade Plug Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P-HG Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (4) 5-15R-HG Circuit Breaker (amps) 15 Overload Protection 15A resettable circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 4 Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Switches No power switch SURGE / NOISE SUPPRESSION Automatic Shut-Off Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Color White Material of Construction Metal Power Cord Color White Housing Color White Included Mounting Accessories Mounting tabs and flanges Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between keyhole tabs = 261.92mm; Distance between end tabs = 334.01mm Outlets Measurement (Center to Center) 3.62 in. Receptacle Color White Shipping Dimensions (hwd / in.) 14.17 x 5.98 x 2.17 Shipping Dimensions (hwd / cm) 35.99 x 15.19 x 5.51 Shipping Weight (lbs.) 3.60 Shipping Weight (kg) 1.63 Unit Dimensions (hwd / in.) 1.500 x 13.750 x 2.500 Unit Dimensions (hwd / cm) 3.8 x 34.9 x 6.4 Unit Weight (lbs.) 3.20 Unit Weight (kg) 1.45 Mounting Details Includes flanges FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial Yes Built-In Circuit Breaker Yes Antibacterial No Built-in Cable Management No STANDARDS & COMPLIANCE Patented Patent # 7,375,939 Product Certifications CSA (Canada); CAN/CSA-C22.2 No. 601.1; CAN/CSA-C22.2 No. 601.1-M90 (Canada); CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1; UL 1363; UL 60601-1 Product Compliance NFPA 99: 10.2.3.6; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PS-415-HGULTRA
物料型号:PS-415-HGULTRA
器件简介:PS-415-HGULTRA 是 Tripp Lite 公司生产的一款医疗级电源条,具备完整的 UL 60601-1 合规性和机构认证,适用于所有病人护理区域的独立使用。
这款电源条拥有专利保护电路,可防止在发生故障时电源到达其插口,从而保护使用者免受电击危险。
引脚分配:电源条配备了一个 NEMA 5-15P-HG 医疗级插头和四个 NEMA 5-15R-HG 医疗级插口,这些插口均包含集成锁定安全罩。
参数特性:这款电源条支持 120V AC 输入电压,频率兼容性为 50/60Hz,配备了 15A 可重置电路断路器,以防止过载,且没有电源开关。
功能详解:PS-415-HGULTRA 电源条提供自动现场故障保护,电路断路器在故障威胁消失后可以自动重置。
电源条还采用了抗菌粉末涂层,有助于防止细菌、病毒、真菌、霉菌和霉变的生长。
应用信息:这款电源条适用于医疗设施中的任何电源分配需求,包括病人护理区域、治疗室、成像环境和行政区域。
封装信息:电源条的外壳为全金属材质,颜色为白色,尺寸为 1.500x13.750x2.500 英寸(约 3.8x34.9x6.4 厘米),重量为 3.20 磅(约 1.45 公斤)。
电源线长度为 15 英尺(约 4.57 米),颜色为白色。
电源条还包括安装用的安装片和法兰。
此外,PS-415-HGULTRA 电源条还符合 UL 60601-1 和 UL 60950-1 规范,并拥有专利 #7,375,939。
产品还通过了 CSA、CAN/CSA-C22.2 No. 601.1、CAN/CSA-C22.2 No. 60950-1、UL 1363 等多种认证,符合 NFPA 99:10.2.3.6 和 RoHS 标准。
产品提供有限的终身保修。
PS-415-HGULTRA 价格&库存
很抱歉,暂时无法提供与“PS-415-HGULTRA”相匹配的价格&库存,您可以联系我们找货
PS-415-HGULTRA
    库存:2
