PS240810
PS240810
    TRIPPLITE
    POWERSTRIP120V8OUTVERT10'
PS240810 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8-Outlet Vertical Power Strip, 120V, 15A, 10 ft. (3.05 m) Cord, 5-15P, 24 in. Highlights ● Ideal for applications needing multiple convenience outlets for powering a variety of electronic equipment24-in mountable housing with 8 standard NEMA 5-15R outlets and a 10-ft. (3.05 m) power cord ● Lighted, covered On/Off switch and 15-amp circuit breaker ● Sturdy construction and heavyduty, all-metal housing MODEL NUMBER: PS240810 Package Includes The PS240810 power strip provides horizontal or vertical power distribution for rackmount, raceway and workbench applications in a convenient 24-inch mountable housing. Description The PS240810 provides a 15-amp, 120v power strip with 8 standard NEMA 5-15 outlets in a rugged, allmetal, mountable housing. It allows for both vertical and horizontal mounting, making it ideal for a variety of uses including office, rackmount, workbench, industrial and telecom applications. With a NEMA 5-15P, 10-ft. (3.05 m) power cord, you don't have to install the PS240810 next to outlets you already have; it can be mounted across the room and deliver reliable service where you need it most. A lighted and covered On/Off switch helps prevent accidental shut-offs, while a 15-amp circuit breaker guards against dangerous circuit overloads. Its sturdy all-metal extruded aluminum housing stands up to demanding network, laboratory or factory environments. Features Multi-Outlet Power Distribution: Vertical or Horizontal Mounting: Extra Long Power Cord: Premium Safety Features: Heavy-Duty Housing: Specifications 1/3 ● PS240810 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332187512 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Right-Angle Plug No Input Cord Length (m) 3.05 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (8) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (4) Yes Right-Angle Outlets No Outlet Spacing 2.48 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Outlets Measurement (Center to Center) 2.48 in. Receptacle Color Black 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 2.50 x 4.60 x 28.20 Shipping Dimensions (hwd / cm) 6.35 x 11.68 x 71.63 Shipping Weight (lbs.) 2.90 Shipping Weight (kg) 1.32 Unit Dimensions (hwd / in.) 1.250 x 1.500 x 24.200 Unit Dimensions (hwd / cm) 61.97 x 3.18 x 3.8 Unit Weight (lbs.) 2.16 Unit Weight (kg) 0.98 Outlet Spacing 2.48 in. FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS240810 价格&库存
很抱歉,暂时无法提供与“PS240810”相匹配的价格&库存,您可以联系我们找货
