TLP76MSG
TLP76MSG
    TRIPPLITE
    SURGESUPPRESSOR7OUT
TLP76MSG 数据手册
Eco-Surge 7-Outlet Surge Protector, 6 ft. (1.83 m) Cord, 1080 Joules, Individually-Controlled MODEL NUMBER: TLP76MSG Highlights ● Individual outlet control ● 1080 joules ● 7 outlet / 6-ft cord ● Diagnostic LEDs Package Includes Description Tripp Lite's TLP76MSG offers reliable, GREEN surge technology that protects your computer and peripherals as well as the environment and your wallet. Energy-saving outlet configuration reduces energy waste (phantom loads) by cutting AC power to unused peripherals. The TLP76MSG has one always on outlet for those peripherals that need constant power like a fax machine, DVR or router. It also offer convenient, individual outlet switches that allow users to select which device is turned on and off. The TLP76MSG has 7 total outlets, 6-ft. (1.83 m) cord and diagnostic LEDs to warn of wiring problems and suppressor damage. Network-grade AC suppression rated at 1080 joules shields equipment from surges and line noise. Designed with an attractive cool gray suppressor housing, the TLP76MSG can accommodate up to 4 transformer plug outlets offering convenient protection of desktop computer equipment and accessories. $25,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● Energy-saving green outlets allow individual outlet control using illuminated power switches for cutting power to peripherals not in use. ● Six green outlets have their own illuminated ON/OFF switch for cutting power to peripherals when they are not in use. One "Always On" outlet provides continuous power for devices such as DVRs (TiVo), cable and satellite boxes, modems, routers and fax machines. ● In addition to the individual illuminated outlet switches, an illuminated Master Switch controls power to all outlets (except the Always On outlet) at once. It can override other "ON" settings to cut power to all switched outlets at once. ● Protected (Green) LED assures protection is present & Always On (Red) LED indicates that the Always On outlet is receiving power. ● 1080 joules surge suppression rating with EMI/RFI line noise filtering help components perform at their peak (sharper, crisper video; deeper, fuller audio and longer component life spans). ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications OVERVIEW 1/4 ● TLP76MSG ECO-SURGE Home/Business Theater Surge Suppressor ● Instruction manual with warranty information UPC Code 037332166074 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 72000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Output Volt Amp Capacity (VA) 120 Output Watt Capacity (Watts) 1800 Frequency Compatibility 60 Hz Output (Watts) 1800 Output Receptacles (7) 5-15R Transformer Accommodation (4) Yes Right-Angle Outlets Yes Individually Controllable Load Banks Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches 1 x Lighted Master Switch & 6 x Lighted Receptacle Switches LED Indicators Protected (Green)" & Always On Receptacle (Red) SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1080 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 400v EMI / RFI Filtering Up to 40 dB 2/4 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Gray Housing Color Gray Mounting Holes or Slots No Slot or Hole Mount Measurement (Center to Center) 300 mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 2.00 x 4.20 x 17.00 Shipping Dimensions (hwd / cm) 5.08 x 10.67 x 43.18 Shipping Weight (lbs.) 1.80 Shipping Weight (kg) 0.82 Unit Dimensions (hwd / in.) 1.40 x 3.40 x 15 Unit Dimensions (hwd / cm) 3.56 x 8.64 x 38.1 Unit Weight (lbs.) 1.54 Unit Weight (kg) 0.70 Input Cord Color Gray FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Industry Canada (Communications) No Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 Connected Equipment Insurance (U.S., Canada & Puerto Rico) $25,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
TLP76MSG 价格&库存
很抱歉,暂时无法提供与“TLP76MSG”相匹配的价格&库存,您可以联系我们找货
