TLP615
TLP615
    TRIPPLITE
    SURGE PROTECT STRIP 6 OUTLET 15'
TLP615 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 6-Outlet Surge Protector, 15 ft. Cord, 790 Joules, Diagnostic LED, Light Gray Housing MODEL NUMBER: TLP615 Highlights ● 6 NEMA 5-15R outlets—one designed for a bulky transformer ● 790-joule surge protection rating ● Filters out threatening EMI/RFI line noise ● 15A resettable circuit breaker prevents dangerous overloads ● 15 ft. AC power cord with NEMA 5-15P plug Package Includes Safeguard your computer, printer, scanner, router, modem and other small home electronics against dangerous surges, spikes and line noise. Recommended for any desktop, network or home application requiring AC line protection. Description Perfect for your home or office workstation, the TLP615 Protect It!® 6-Outlet Surge Protector features a surge protection rating of 790 joules to defend your sensitive electronic components against strong surges and spikes. In fact, Tripp Lite will repair or replace any connected equipment damaged by surges up to $20,000 for life (valid in the U.S., Canada and Puerto Rico only). Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP615 protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/HG). It also filters out electromagnetic interference (EMI) and radio frequency interference (RFI) that can disrupt your electronics and inflict hardware damage or data loss. Your devices plug into six NEMA 5-15R outlets, one of which is placed at the end to accept a bulky transformer without blocking adjacent outlets. An integrated 15A circuit breaker protects all outlets and shuts down connected equipment in case of overload. The lighted on/off switch provides one-touch control over connected equipment. A diagnostic LED confirms your connected equipment is protected. The 15-foot (4.8-meter) AC power cord with NEMA 5-15P plug gives you enough flexibility to reach distant outlets while fitting easily into your workstation or home theater setup. Keyhole slots incorporated into the bottom panel provide convenient wall or desk mounting options for the light gray plastic housing. Features 790-Joule Surge Protection for Home or Office Electronics ● Protects your computer, printer, scanner, router, modem and other small home electronics against even the strongest surges and spikes ● Recommended for any desktop, network or home electronics application requiring AC line protection ● Full normal mode (H-N) and common mode (N-G/H-G) line surge suppression ● Filters out disruptive EMI/RFI line noise that can cause equipment damage or data loss ● Exceeds IEEE 587 Category A and B surge suppression specifications 6 Outlets Accept Wide Range of Electronic Devices ● 6 NEMA 5-15R AC outlets accept most computers and peripherals ● Special end outlet designed for bulky transformers without blocking other outlets Premium Safety Features ● Lighted on/off switch provides one-touch control over connected equipment 1/4 ● TLP615 Protect It! 6-Outlet Surge Protector, Light Gray Housing ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required ● Diagnostic LED confirms protection status at a glance ● Conforms to current UL 1449 3rd Edition safety standards ● ABS fire retardant plastic case provides extra safety and durability Fits Effortlessly Into Your Workstation ● 15 ft. AC power cord with NEMA 5-15P plug reaches distant outlets ● Keyhole slots on bottom panel provide convenient wall or desk mounting options Backed by Tripp Lite's Ultimate Lifetime Insurance ● $20,000 Ultimate Lifetime Insurance covers any connected components damaged by power surge (U.S., Canada and Puerto Rico only) Specifications OVERVIEW UPC Code 037332166418 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 35500 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable illuminated combo switch / circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 outlets Right-Angle Outlets No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position red illuminated on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 790 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500V EMI / RFI Filtering Up to 20 dB Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Light Gray Housing Color Light Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between slots = 101 mm; Distance between slot height = 28 mm Outlets Measurement (Center to Center) 28.5mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 13.20 x 5.80 x 1.80 Shipping Dimensions (hwd / cm) 33.53 x 14.73 x 4.57 Shipping Weight (lbs.) 1.98 Shipping Weight (kg) 0.90 Unit Dimensions (hwd / in.) 10.800 x 1.850 x 1.230 Unit Dimensions (hwd / cm) 27.43 x 4.70 x 3.12 Unit Weight (lbs.) 1.60 Unit Weight (kg) 0.73 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $20,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP615
物料型号:TLP615 器件简介:TLP615 Protect It!
6-Outlet Surge Protector 是一款设计用于保护电子设备免受电涌、尖峰和线路噪声影响的电源保护器。
它具有790焦耳的浪涌保护等级,能够过滤掉有害的电磁干扰(EMI)和射频干扰(RFI)。
引脚分配:提供6个NEMA 5-15R插座,其中一个位于末端,可接受体积较大的变压器,而不会阻挡相邻的插座。
参数特性:具有790焦耳的浪涌保护等级,15A可重置的电路断路器,15英尺的AC电源线,带有NEMA 5-15P插头。
功能详解:能够防御强大的电涌和尖峰,过滤掉可能破坏电子设备并造成硬件损坏或数据丢失的EMI/RFI。
具有全模式(H-N)和共模(N-G/H-G)线路浪涌抑制功能。
应用信息:推荐用于任何需要交流线路保护的桌面、网络或家庭电子设备应用,如计算机、打印机、扫描仪、路由器、调制解调器等。
封装信息:外壳为浅灰色塑料材质,电源线颜色为浅灰色,带有安装孔或槽,便于墙壁或桌面安装。
产品符合UL 1449第3版安全标准,采用ABS阻燃塑料材质,提供额外的安全性和耐用性。
TLP615 价格&库存
很抱歉,暂时无法提供与“TLP615”相匹配的价格&库存,您可以联系我们找货
