1000 Eaton Boulevard
Cleveland, OH 44122
United States
Protect It! 7-Outlet Surge Protector, 25 ft. Cord,
1080 Joules, Diagnostic LED, Light Gray Housing
MODEL NUMBER: TLP725
Highlights
7 NEMA 5-15R outlets—one
designed for a bulky transformer
1080-joule surge protection
rating
Filters out threatening EMI/RFI
line noise
15A resettable circuit breaker
prevents dangerous overloads
25 ft. AC power cord with NEMA
5-15P plug
Package Includes
Safeguard your computer, printer, scanner, router, modem and other small home electronics against
dangerous surges, spikes and line noise.
Description
Perfect for your home or office workstation, the TLP725 Protect It!® 7-Outlet Surge Protector features a
surge protection rating of 1080 joules to defend your sensitive electronic components against strong
surges and spikes. In fact, Tripp Lite will repair or replace any connected equipment damaged by surges
up to $25,000 for life (valid in the U.S., Canada and Puerto Rico only).
Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP725
protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/HG). It also filters out electromagnetic interference (EMI) and radio frequency interference (RFI) that can
disrupt your electronics and inflict hardware damage or data loss.
Your devices plug into seven NEMA 5-15R outlets, one of which is spaced apart to accept a bulky
transformer without blocking adjacent outlets. An integrated 15A circuit breaker protects all outlets and
shuts down connected equipment in case of overload. The lighted on/off switch provides one-touch control
over connected equipment. A diagnostic LED confirms your connected equipment is protected.
The extra-long 25-foot (7.6-meter) AC power cord with NEMA 5-15P plug gives you flexibility to reach
distant outlets while fitting easily into your workstation or home theater setup. Keyhole slots incorporated
into the bottom panel provide convenient wall or desk mounting options for the light gray plastic housing.
Features
1080-Joule Surge Protection for Home or Office ElectronicsProtects your computer, printer, scanner,
router, modem and other small home electronics against even the strongest surges and
spikesRecommended for any desktop, network or home electronics application requiring AC line
protectionFull normal mode (H-N) and common mode (N-G/H-G) line surge suppressionFilters out
disruptive EMI/RFI line noise that can cause equipment damage or data lossExceeds IEEE 587 Category
A and B surge suppression specifications
7 Outlets Accept Wide Range of Electronic Devices7 NEMA 5-15R AC outlets accept most computers
and peripheralsSpecial end outlet designed for bulky transformers without blocking other outlets
Premium Safety FeaturesLighted on/off switch provides one-touch control over connected
equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated,
preventing equipment damage and indicating replacement is requiredDiagnostic LED confirms protection
status at a glanceConforms to current UL 1449 3rd Edition safety standardsABS fire retardant plastic case
provides extra safety and durability
1/4
TLP725 Protect It! 7-Outlet
Surge Protector, Light Gray
Housing
Owner’s manual
Cleveland, OH 44122
United States
Fits Effortlessly Into Your WorkstationExtra-long 25 ft. AC power cord with NEMA 5-15P plug reaches
distant outletsKeyhole slots on bottom panel provide convenient wall or desk mounting options
Backed by Tripp Lite's Ultimate Lifetime Insurance$25,000 Ultimate Lifetime Insurance covers any
connected components damaged by power surge (U.S., Canada and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332138316
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Cord Gauge Type
14 gauge; SJT
Input Cord Gauge (AWG)
14
Voltage Compatibility (VAC)
120
Maximum Surge Amps
72000
Input Plug Type
NEMA 5-15P
Input Cord Details
SJT
Input Cord Length (ft.)
25
Right-Angle Plug
No
Input Cord Length (m)
7.62
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(7) 5-15R
Circuit Breaker (amps)
15
Transformer Accommodation
(2) Yes
Outlet Orientation
Single row
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Switches
Combination AC circuit breaker and illuminated on/off power switch
Diagnostic LED Details
Built-in LED confirms suppressor "protection present" (green) status
2/4
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
1080
AC Suppression Response Time
< 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression
UL1449 Let Through Rating
400V
EMI / RFI Filtering
Up to 20 dB
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Telephone/DSL Protection
No
PHYSICAL
Material of Construction
Plastic
Power Cord Color
Gray
Housing Color
Gray
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
Distance between slots = 151 mm; Distance between slot height = 24 mm
Outlets Measurement (Center to
Center)
Distance between standard outlets = 29mm; Distance between last standard outlet and transformer outlet = 33mm
Receptacle Color
White
Shipping Dimensions (hwd / in.)
2.40 x 6.50 x 14.00
Shipping Dimensions (hwd / cm)
6.10 x 16.51 x 35.56
Shipping Weight (lbs.)
3.32
Shipping Weight (kg)
1.51
Unit Dimensions (hwd / in.)
1.320 x 2.050 x 11.690
Unit Dimensions (hwd / cm)
3.35 x 5.21 x 29.69
Unit Weight (lbs.)
3.04
Unit Weight (kg)
1.38
Input Cord Color
White
FEATURES & SPECIFICATIONS
Antimicrobial
No
Rotatable Outlets
No
3/4
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Industry Canada (Communications)
No
Product Certifications
CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL
1363; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“TLP725”相匹配的价格&库存,您可以联系我们找货
