1000 Eaton Boulevard
Cleveland, OH 44122
United States
Protect It! 8-Outlet Surge Protector, 25 ft. Cord
with Right-Angle Plug, 1440 Joules, Diagnostic
LEDs, Light Gray Housing
MODEL NUMBER: TLP825
Highlights
8 NEMA 5-15R outlets, including
3 for bulky transformers
1440-joule surge protection
rating
Filters out threatening EMI/RFI
line noise
15A resettable circuit breaker
prevents dangerous overloads
25 ft. AC power cord with rightangle NEMA 5-15P plug
Package Includes
Safeguard your computer, printer, scanner, router, modem and other small home electronics against
dangerous surges, spikes and line noise.
Description
Perfect for your home or office workstation, the TLP825 Protect It!® 8-Outlet Surge Protector features a
surge protection rating of 1440 joules to defend your sensitive electronic components against even the
strongest surges and spikes. In fact, Tripp Lite will repair or replace any connected equipment damaged
by surges up to $75,000 for life (valid in the U.S., Canada and Puerto Rico only).
Because residential power outlets have three wires—hot line (H), neutral (N) and ground (G)—the TLP825
protects all three, covering the two protection modes: full normal mode (H-N) and common mode (N-G/HG). It also filters out electromagnetic interference (EMI) and radio frequency interference (RFI) that can
disrupt your electronics and inflict hardware damage or data loss.
Your devices plug into eight NEMA 5-15R outlets, three of which are widely spaced to accept bulky
transformers without blocking adjacent outlets. Sliding safety covers block accidental contact with unused
outlets. An integrated 15A circuit breaker protects all outlets and shuts down connected equipment in case
of overload. The lighted on/off switch provides one-touch control over connected equipment. Diagnostic
LEDs confirm your wall outlet is properly grounded and your connected equipment is protected.
The extra-long 25-foot (7.6-meter) AC power cord gives you flexibility to reach distant outlets, while its
right-angle NEMA 5-15P plug allows furniture and equipment to be moved flush against the wall to save
space in your workstation. Keyhole slots incorporated into the bottom panel provide convenient wall or
desk mounting options for the light gray plastic housing.
Features
1440-Joule Surge Protection for Home or Office ElectronicsProtects your computer, printer, scanner,
router, modem and other small home electronics against even the strongest surges and
spikesRecommended for any desktop, network or home electronics application requiring AC line
protectionFull normal mode (H-N) and common mode (N-G/H-G) line surge suppressionFilters out
disruptive EMI/RFI line noise that can cause equipment damage or data lossExceeds IEEE 587 Category
A and B surge suppression specifications
8 Outlets Accept Wide Range of Electronic Devices8 NEMA 5-15R AC outlets accept most computers
and peripherals3 widely spaced outlets accommodate bulky transformers without blocking other
outletsSliding safety covers block accidental contact with unused outlets
Premium Safety FeaturesLighted on/off switch provides one-touch control over connected
equipmentAutomatic shutoff permanently cuts power to outlets if protection circuit is incapacitated,
1/4
TLP825 Protect It! 8-Outlet
Surge Protector, Light Gray
Housing
Owner’s manual
Cleveland, OH 44122
United States
preventing equipment damage and indicating replacement is requiredDiagnostic LEDs confirm grounding
and protection status at a glanceConforms to current UL 1449 3rd Edition safety standardsABS fire
retardant plastic case provides extra safety and durability
Fits Effortlessly Into Your WorkstationExtra-long 25 ft. AC power cord reaches distant outletsSpacesaving right-angle NEMA 5-15P plug allows furniture and equipment to move flush against the
wallKeyhole slots on bottom panel provide convenient wall or desk mounting options
Backed by Tripp Lite's Ultimate Lifetime Insurance$75,000 Ultimate Lifetime Insurance covers any
connected components damaged by power surge (U.S., Canada and Puerto Rico only)
Specifications
OVERVIEW
UPC Code
037332138248
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Plug Features
Right Angle (36D)
Input Cord Gauge Type
14 gauge; SJT
Input Cord Gauge (AWG)
14
Voltage Compatibility (VAC)
120
Maximum Surge Amps
84000
Input Plug Type
NEMA 5-15P
Input Cord Details
SJT
Input Cord Length (ft.)
25
Right-Angle Plug
Yes
Input Cord Length (m)
7.62
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(8) 5-15R
Circuit Breaker (amps)
15
Transformer Accommodation
(6) Yes
Outlet Orientation
Single row of 5, plus a second row of 3 for transformer accommodation
Right-Angle Outlets
No
Outlet Safety Covers Detail
Includes built-in sliding outlet safety covers
2/4
Cleveland, OH 44122
United States
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Switches
Combination AC circuit breaker and 2 position red illuminated on/off power switch
Diagnostic LED Details
Built-in LEDs confirm suppressor "protection present" (green) and "grounded" (red) status
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
1440
AC Suppression Response Time
< 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression
UL1449 Let Through Rating
330/400/400
EMI / RFI Filtering
Up to 40 dB
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Telephone/DSL Protection
No
PHYSICAL
Material of Construction
Plastic
Power Cord Color
Gray
Housing Color
Gray
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
Distance between horizontal slots = 75 mm; Distance between vertical slots = 41.6 mm
Outlets Measurement (Center to
Center)
Distance between standard outlets = 28.5mm; Distance between transformer outlets = 57mm
Receptacle Color
Gray
Shipping Dimensions (hwd / in.)
12.40 x 4.10 x 5.20
Shipping Dimensions (hwd / cm)
31.50 x 10.41 x 13.21
Shipping Weight (lbs.)
3.70
Shipping Weight (kg)
1.68
Unit Dimensions (hwd / in.)
4.860 x 9.550 x 1.510
Unit Dimensions (hwd / cm)
12.34 x 24.26 x 3.84
Unit Weight (lbs.)
3.46
Unit Weight (kg)
1.57
Input Cord Color
White
3/4
Cleveland, OH 44122
United States
FEATURES & SPECIFICATIONS
Rotatable Outlets
No
Antimicrobial
No
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL
1363; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“TLP825”相匹配的价格&库存,您可以联系我们找货
