TR-6FM
TR-6FM
    TRIPPLITE
    6OUTLET6'CORDSURGESUPPRESS
TR-6FM 数据手册
Protect It! 6-Outlet Surge Protector, 6 ft. (1.83 m) Cord, 3040 Joules, Tel/DSL Protection MODEL NUMBER: TR-6FM Highlights ● 6 outlets/6-ft. (1.83 m) cord ● 3040 joule rating ● Modem/fax surge protection Package Includes Description The TR-6FM Surge Suppressor from Tripp Lite has 6 outlets and a 6-ft. (1.83 m) cord with a space-saving right-angle plug. The unit has 3040 joules of surge energy absorption to handle the strongest surges. Built-in RJ11 jacks prevent surges from damaging your modem/fax/phone equipment. A 6-ft. (1.83 m) telephone cord is also included. Diagnostic LEDs alert the user to potential power problems. $50,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). The Super Surge Alert+Tel comes with child safety covers and color-coded cord identifiers. Features ● 6 outlets with child safety covers ● 6-ft. (1.83 m) cord with space-saving right-angle plug ● Built-in RJ11 jacks prevent surges from damaging your modem/fax/phone equipment; 6-ft. (1.83 m) telephone cord included ● Surge energy absorption: 3040 joules; 85,000 amps ● 15 amp circuit breaker ● 3 diagnostic LEDs indicate AC present, line fault & protection present ● EMI/RFI noise filtering ● Logical outlet spacing accommodates transformers without blocking remaining outlets ● Keyhole supports for wall mounting ● Recessed and lighted power switch ● Color-coded cord identifiers ● $50,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) covers connected equipment ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications 1/4 ● TR-6FM Surge Suppressor ● 6-ft. (1.83 m) Telephone cord ● Child Safety Covers ● Color-coded cord identifiers ● Warranty information with instruction manual OVERVIEW UPC Code 037332010612 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 105000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug Yes Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position red illuminated on/off power switch Diagnostic LED Details PROTECTION PRESENT (green), LINE FAULT (red) and LINE OK (green) SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 3040 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression AC Suppression Surge Current Rating 78,500 amps UL1449 Let Through Rating 400V - UL Verified EMI / RFI Filtering Yes 2/4 Immunity Conforms to IEE 587 / ANSI C62.41 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Telephone/DSL Protection Details 1 line Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection Yes PHYSICAL Material of Construction Plastic Power Cord Color Light Gray Housing Color Light Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 88.8 mm Outlets Measurement (Center to Center) Distance between horizontal outlets = 44.20mm; Distance between vertical outlets = 39mm Receptacle Color Light gray Shipping Dimensions (hwd / in.) 2.00 x 6.00 x 12.50 Shipping Dimensions (hwd / cm) 5.08 x 15.24 x 31.75 Shipping Weight (lbs.) 2.30 Shipping Weight (kg) 1.04 Unit Dimensions (hwd / in.) 1.75 x 3.5 x 9.5 Unit Dimensions (hwd / cm) 4.45 x 8.9 x 24.13 Unit Weight (lbs.) 1.65 Unit Weight (kg) 0.75 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Industry Canada (Communications) Industry Canada Product Certifications UL 1449; UL 497A Product Compliance FCC Part 68; RoHS WARRANTY 3/4 Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $50,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
TR-6FM 价格&库存
很抱歉,暂时无法提供与“TR-6FM”相匹配的价格&库存,您可以联系我们找货
