SUPER7TEL15
SUPER7TEL15
    TRIPPLITE
    SURGE SUPPR 7OUT 15'CORD W/RJ11
SUPER7TEL15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 7-Outlet Surge Protector, 15 ft. (4.57 m) Cord, 2520 Joules, Fax/Modem Protection, RJ11 MODEL NUMBER: SUPER7TEL15 Highlights ● 7 outlets / 15-ft. (4.57 m) cord ● 2520 joule rating ● Modem/fax surge protection Package Includes Description Tripp Lite's SUPER7TEL15 surge suppressor offers complete AC and phone line surge suppression for comprehensive protection of workstations, desktop PCs, telecom systems and other sensitive electronics. Heavy grade AC surge suppression shields connected equipment from damage and performance problems due to transient surges. Set of RJ11 telephone line suppression jacks protect dialup and DSL modem lines, fax machines, cordless phones and more. SUPER7TEL15 offers 7 total outlets, extra-long 15-ft. (4.57 m) cord with space-saving angled plug and diagnostic LEDs to warn of wiring problems and suppressor damage. Heavy grade AC suppression rated at 2520 joules shields equipment from surges and line noise. Attractive gray suppressor housing with keyhole mounting slots and 3 designated transformer plug outlets offers convenient protection of desktop computer equipment and accessories. $75,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). PLUG/OUTLETS: Input: NEMA5-15P/Output: 7 NEMA5-15R/15-ft. AC line cord ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires NEMA5-15R wall receptacle) FORMAT: Corded multi-outlet strip with 3 transformer spaced outlets SUPPRESSION: AC: 150V RMS Clamping/2520 joules/330 L-G, 400 L-N, 400 N-G UL1449 Let-through Phone: Single telephone line surge suppression (RJ11 jacks, 2 wire, 1 line) Features ● 2520 joules AC surge suppression shields equipment from the strongest surges and line noise ● 7 AC outlets with room for 3 transformer plugs without blocking outlets covers computers and all peripherals ● Phone line surge suppression protects both dialup and DSL modems, plus fax machines, cordless phones and more (pair of RJ11 jacks, 2 wire, 1 line, includes 6 ft phone cable) ● Extra long 15-ft. (4.57 m) AC line cable with space-saving angle input plug conveniently reaches distant outlets ● Built-in power switch and 15 amp circuit breaker offers power control and overload protection over all outlets ● Fail-safe thermal fusing protects against fire and other damage in the event of an extreme, extended overvoltage or surge condition ● Diagnostic LEDs confirm outlet grounding and surge suppression status ● Attractive gray suppressor housing with keyhole mounting tabs allow versatile placement options ● UL1449 Rated, UL1363 (Power Tap), UL497A (Communications), Meets FCC part 68 rules, cUL (Canada) 1/4 ● SUPER7TEL15 Surge Suppressor ● 6-ft. (1.83 m) telephone cord ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States ● Exceeds IEEE 587 category A & B surge suppression specifications ● $75,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications OVERVIEW UPC Code 037332095381 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Plug Features Right Angle (36D) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 156000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 15 Right-Angle Plug Yes Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (7) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (4) Yes Outlet Orientation Single row of 5, plus 2 side mounted outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two position on/off power switch Diagnostic LED Details Built-in LEDs confirm suppressor "protection present" (green) and "grounded" (red) status 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 2520 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 330 L-G, 400 L-N, 400 N-G EMI / RFI Filtering Up to 20 dB Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Telephone/DSL Protection Details 1 line Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection Yes PHYSICAL Material of Construction Plastic Power Cord Color Gray Housing Color Gray Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between slots = 70 mm; Distance between slot height = 24 mm Outlets Measurement (Center to Center) Between Standard Outlets = 29mm; Between Transformer Outlets = 48mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 12.00 x 2.00 x 7.20 Shipping Dimensions (hwd / cm) 30.48 x 5.08 x 18.29 Shipping Weight (lbs.) 1.70 Shipping Weight (kg) 0.77 Unit Dimensions (hwd / in.) 1.540 x 2.720 x 10.300 Unit Dimensions (hwd / cm) 3.91 x 6.91 x 26.16 Unit Weight (lbs.) 2.13 Unit Weight (kg) 0.97 Input Cord Color White FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States STANDARDS & COMPLIANCE Industry Canada (Communications) Industry Canada Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 1363; UL Listed Product Compliance FCC Part 68; RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $75,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SUPER7TEL15
物料型号:SUPER7TEL15
器件简介:SUPER7TEL15浪涌保护器为工作站、台式电脑、电信系统和其他敏感电子设备提供全面的交流和电话线浪涌抑制。
引脚分配:7个AC插座,包括5个一排的插座和2个侧面安装的插座,以及1个电话线浪涌抑制插座(2线,1线,包括6英尺电话线)。
参数特性:2520焦耳的交流浪涌抑制,15英尺(4.57米)长的AC线缆,内置15安培断路器和电源开关,诊断LED指示浪涌抑制状态和接地状态。
功能详解:提供交流和电话线浪涌抑制,保护设备免受浪涌和线路噪声的影响,具有故障安全热熔断保护,自动关闭功能,以及符合FCC第68部分规则和UL1449、UL1363、UL497A标准的认证。
应用信息:适用于需要保护敏感电子设备免受电力浪涌影响的场合,如家庭、办公室和数据中心。
封装信息:灰色外壳,带有安装槽,可以挂墙安装,输入线缆为14号SJT型,长度15英尺(4.57米),电源插头为直角型NEMA 5-15P。
SUPER7TEL15 价格&库存
很抱歉,暂时无法提供与“SUPER7TEL15”相匹配的价格&库存,您可以联系我们找货
