PSF2408
PSF2408
    TRIPPLITE
    POWERSTRIP24"8OUT15'CORD
PSF2408 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 8-Outlet Foldable Power Strip with 1 Pivot, 120V, 12A, 15 ft. (4.57 m) Cord, 5-15P, 24 in. MODEL NUMBER: PSF2408 Highlights ● Foldable, single pivot 24-in mountable housing ● 8 standard NEMA 5-15R outlets and a 15-ft. (4.57 m) power cord ● Lighted, covered On/Off switch and 12-amp circuit breaker ● Sturdy construction and heavyduty, all-metal housing Package Includes Foldable design is ideal for using around corners and tight spaces, by multiple users, or anywhere you need a flexible power strip that can fold in half to accommodate multiple environments. Description The PSF2408 provides a 12-amp, 120v power strip with 8 standard NEMA 5-15 outlets in a rugged, allmetal, mountable housing that folds in the middle. It allows for both vertical and horizontal mounting with additional mounting clips to ensure the pivot stays in place. The PSF2408 is ideal for a variety of uses including office, rack-mount, workbench, industrial and telecom applications. With a NEMA 5-15P, 15-ft. (4.57 m) power cord, you don't have to install it next to outlets you already have; it can be mounted across the room and deliver reliable power where you need it most. With a foldable center pivot, the PSF2408 can go around corners, be used by more than 1 person, and fit in smaller spaces. A lighted and covered On/Off switch helps prevent accidental shut-offs, while a 12-amp circuit breaker guards against dangerous circuit overloads. Its sturdy all-metal extruded aluminum housing stands up to demanding network, laboratory or factory environments. Features Multi-Outlet, Foldable Power Distribution Vertical or Horizontal Moun Extra Long Power Cord Premium Safety Features Heavy-Duty Housing Specifications OVERVIEW 1/3 ● PSF2408 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332187529 INPUT Nominal Input Voltage(s) Supported 120V AC Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (8) 5-15R Circuit Breaker (amps) 12 Transformer Accommodation (4) Yes Right-Angle Outlets No Outlet Spacing 1.18 in 1st segment and 2.25 is second segment USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Receptacle Color Black Shipping Dimensions (hwd / in.) 2.40 x 4.40 x 27.50 Shipping Dimensions (hwd / cm) 6.10 x 11.18 x 69.85 Shipping Weight (lbs.) 0.28 Shipping Weight (kg) 0.13 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 1.260 x 1.620 x 24.940 Unit Dimensions (hwd / cm) 3.20 x 4.11 x 63.65 Unit Weight (lbs.) 2.88 Unit Weight (kg) 1.31 Outlet Spacing 1.18 in. 1st segment; 2.25 in. second segment FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 60950-1; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PSF2408 价格&库存
很抱歉,暂时无法提供与“PSF2408”相匹配的价格&库存,您可以联系我们找货
