PS120420
PS120420
    TRIPPLITE
    POWERSTRIP
PS120420 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 4-Outlet Vertical Power Strip, 2-15A & 2-20A, 120V, 15 ft. (4.57 m) Cord, 5-20P, 12 in. Highlights ● Ideal for applications needing multiple convenience outlets for powering a variety of electronic equipment ● 12-in. mountable housing with 2 NEMA 5-15R and 2 NEMA 520R outlets and a 15-ft. (4.57 m) power cord ● Lighted, covered On/Off switch and 20-amp circuit breaker ● Sturdy construction and heavyduty, all-metal housing MODEL NUMBER: PS120420 Package Includes The P120420 power strip provides horizontal or vertical power distribution for rackmount, raceway and workbench applications in a convenient 12-in. mountable housing. Description The PS120420 provides a 20-amp, 120v power strip with 2 standard NEMA 5-15 outlets and 2 NEMA 520R outlets in a rugged, all-metal, mountable housing. It allows for both vertical and horizontal mounting, making it ideal for a variety of uses including office, rackmount, workbench, industrial and telecom applications. With a NEMA 5-20P, 15-ft. (4.57 m) power cord, you don't have to install the PS120420 next to outlets you already have; it can be mounted across the room and deliver reliable service where you need it most. A lighted and covered On/Off switch helps prevent accidental shut-offs, while a 20-amp circuit breaker guards against dangerous circuit overloads. Its sturdy all-metal extruded aluminum housing stands up to demanding network, laboratory or factory environments. Features Multi-Outlet Power Distribution Vertical or Horizontal Mounting Extra Long Power Cord Premium Safety Features Heavy-Duty Housing Specifications OVERVIEW UPC Code 037332186126 1/3 ● PS120420 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 20A 120V Input Cord Gauge Type 12 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-20P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (2) 5-15R; (2) 5-20R Circuit Breaker (amps) 20 Transformer Accommodation (2) Yes Right-Angle Outlets No Outlet Spacing 1.77 in center to center. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Outlets Measurement (Center to Center) 1.77 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 3.70 x 6.00 x 15.70 Shipping Dimensions (hwd / cm) 9.40 x 15.24 x 39.88 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 3.60 Shipping Weight (kg) 1.63 Unit Dimensions (hwd / in.) 1.250 x 1.620 x 12.000 Unit Dimensions (hwd / cm) 4.21 x 6.34 x 15.6 Unit Weight (lbs.) 2.75 Unit Weight (kg) 1.25 Outlet Spacing 1.77 in. FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS120420
在尝试翻译PDF文档内容时,遇到了服务超时的问题。
我将尝试重新翻译。
1. 物料型号:PS120420 2. 器件简介:4-Outlet Vertical Power Strip,具有2-15A和2-20A的插座,120V,15英尺(4.57米)的电源线,5-20P,12英寸。
3. 引脚分配:2个NEMA 5-15R插座和2个NEMA 5-20R插座。
4. 参数特性:支持120V AC输入电压,推荐电气服务为20A 120V,电源线规格为12号SJT,电源线长度为15英尺(4.57米),带有20A电路断路器。
5. 功能详解:提供多插座电源分配,支持垂直或水平安装,超长电源线,高级安全特性,重型外壳。
6. 应用信息:适用于需要多个便利插座为各种电子设备供电的应用,如办公室、机架安装、工作台、工业和电信应用。
7. 封装信息:银色,由铝制成,支持在机架外壳、赛百味和其他多种应用中垂直或水平安装,包括安装夹,外壳颜色为银色。
PS120420 价格&库存
很抱歉,暂时无法提供与“PS120420”相匹配的价格&库存,您可以联系我们找货
