PS361220
PS361220
    TRIPPLITE
    POWER STRIP 36" 12OUT 15'CORD
PS361220 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 12-Outlet (10-15A & 2-20A) Vertical Power Strip, 120V, 20A, 15 ft. (4.57 m)Cord, 5-20P, 36 in. Highlights ● 12-outlet (ten 5-15R & two 520R) power strip with a 15-ft. (4.57 m) Cord and an industrialgrade 5-20P plug ● Rated at 1800W, 120V, featuring a 20A resettable circuit breaker to prevent circuit overloads ● Easy-to-install, vertical or horizontal mounting with included mounting clips ● Rocker-style, illuminated power switch with safety cover to prevent accidental turn offs ● RoHS-compliant and certified to meet UL 1363 standards MODEL NUMBER: PS361220 Package Includes Add extra power outlets in rack-mount, workbench, office, retail displays and telecom applications, or any area that needs to power many electrical devices in close proximity to one another from a single AC wall outlet. Description Need to power many pieces of equipment in close proximity to one another but don't have enough outlets to power them all? Tripp Lite's PS361220 12-outlet vertical power strip will give you the outlets where you need them, when you need them. The PS361220 contains a 15-ft. (4.57 m) (14/3 SJT) cord, 10 standard NEMA 5-15R and 2 commercial-use NEMA 5-20R outlets. Each outlet is spaced 2.64-in. apart (center-tocenter) - wide enough for many types of transformers or AC adapters without blocking adjacent outlets. Encased in a rugged, all-metal housing, it comes with mounting clips for either vertical and horizontal mounting, making the PS361220 ideal for a variety of uses in rack-mount, workbench, industrial, office and telecom environments. An illuminated, rocker-style, power switch with a transparent guard prevents accidental turn-offs, while a 20-amp circuit breaker guards against dangerous circuit overloads. To match the decor of most professional settings, it has an extruded aluminum housing with black receptacles. Features Multi-Outlet 120V Power Distribution for Rack-Mount, Raceway and Workbench Applications ● 1800W, 120V, 20A, corded, multi-outlet power strip that safely connects multiple electrical devices to a single AC wall socket ● Saves the time and cost of installing new power outlets in un-powered areas ● Ideal for branch circuit power distribution to telecommunications, computers or internetworking equipment in rack enclosures, workbenches, table tops, work stations, offices, factories, repair shops, hobby shops, test stands and engineering labs 12 Convenient Outlets Power All Standard Electrical Equipment ● Features 12 outlets (10 NEMA 5-15R and 2 NEMA 5-20R) that are compatible with all standard electrical and electronic equipment ● Each outlet is 2.64 inches apart (center to center) - wide enough to fit transformers or AC adapters without blocking adjacent outlets, so you can fully utilize the power strip all the time ● An extra-long, 15-ft. (4.57 m), 14 AWG, 3-wire, SJT cord can reach wall outlets mounted in a different area or room from where it draws AC power, putting you in control of getting reliable power where you need it most 1/4 ● PS361220 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Easy-to-Install, Vertical and Horizontal Mounting Options ● Offers a convenient method of optional horizontal or vertical power distribution. Mounting clips are included. ● Its 36-in. length and strip-style, bench/cabinet, form factor fits in the most confined spaces unobtrusively ● Weighing less than 4 lbs (1.8 kgs), the PS361220 is both easy to handle and effortless to install Built-In, Automatic Safety Features ● An illuminated, rocker-style, power switch with a transparent guard prevents accidental turn offs, while still allowing you to see whether the PS361220 is operational at a glance ● An integral, 20-amp resettable circuit breaker prevents dangerous circuit overloads that can irreversibly damage connected equipment ● The breaker automatically disconnects AC input power to the PS361220 when it detects that the equipment load is drawing too much current Rugged, Durable Housing ● A rugged, all-metal housing is durably constructed to stand up to demanding network, laboratory or factory environments ● An attractive, extruded aluminum housing with stylish black receptacles matches the decor of most professional settings Specifications OVERVIEW UPC Code 037332186638 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 20A 120V Input Cord Gauge Type 12 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-20P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (10) 5-15R; (2) 5-20R Circuit Breaker (amps) 20 Transformer Accommodation (6) Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Right-Angle Outlets No Outlet Spacing 2.64 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Outlets Measurement (Center to Center) 2.64 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 2.40 x 4.40 x 40.00 Shipping Dimensions (hwd / cm) 6.10 x 11.18 x 101.60 Shipping Weight (lbs.) 4.50 Shipping Weight (kg) 2.04 Unit Dimensions (hwd / in.) 1.250 x 1.500 x 36.000 Unit Dimensions (hwd / cm) 3.18 x 3.81 x 91.4 Unit Weight (lbs.) 3.79 Unit Weight (kg) 1.72 Outlet Spacing 2.64 in. FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
PS361220 价格&库存
很抱歉,暂时无法提供与“PS361220”相匹配的价格&库存,您可以联系我们找货
