SS480806
SS480806
    TRIPPLITE
    POWERSTRIP
SS480806 数据手册
8-Outlet Power Strip with Surge Protection, 6 ft. (1.83 m) Cord, 1650 Joules, 48 in. length Highlights ● 8 NEMA 5-15R outlets with 5.28-in. center-to-center spacing – wide enough for transformers without blocking adjacent outlets ● Rated at 1800W, 120V, 15A, featuring a resettable circuit breaker to prevent circuit overloads ● Integral, premium-grade, 1650Joule surge suppressor to protect sensitive electronics from destructive AC transient surges ● Vertical or horizontal mounting with adjustable mounting clamps ● Rocker-style, illuminated power switch with locking safety cover to prevent accidental turn offs ● Certified to meet UL 1449 3rd Edition and UL 1363 standards MODEL NUMBER: SS480806 Package Includes Easily add extra surge-protected power outlets with extra wide spacing in computer rooms, workbenches, repair shops, labs or anywhere that needs to connect many electrical devices simultaneously to a single AC wall outlet. Features Multi-Outlet 120V Power Distribution and Surge Protection for Locations with Limited Free Space ● 1800W, 120V, 15A, corded, multi-outlet power strip that connects multiple electrical devices in close proximity to a single AC wall socket ● Contains an integral surge protector to eliminate the need for a separate desktop unit that can clutter up your work space ● Saves the time and cost of installing new outlets in un-powered areas ● Ideal for branch circuit power distribution to telecommunications, computers or internetworking equipment in rack enclosures, workbenches, table tops, work stations, offices, factories, repair shops, test stands and engineering labs 8 Widely Spaced Outlets That Fit Transformers or AC Adapters without Blocking Adjacent Outlets ● Features 8 NEMA 5-15R outlets that are compatible with all standard electrical equipment ● Each outlet is spaced 5.28 inches apart (center to center) – wide enough to fit transformers or AC adapters without blocking adjacent outlets, so you can fully utilize the power strip all the time Premium-Grade, Surge Suppression to Protect Against Destructive Surges and Line Noise ● Contains a premium-grade surge suppressor rated at 1650 Joules that goes well beyond competing surge protectors, giving you an exceptional level of AC transient surge and EMI/RFI line noise protection for computers and other sensitive electronics Adjustable Vertical and Horizontal Mounting Options ● A convenient method of optional horizontal or vertical power distribution ● Its 48-in. length and strip-style form factor fits in the most confined spaces unobtrusively ● Easy-to-install with adjustable mounting clamps 1/4 ● SS480806 Power Strip/Surge Suppressor ● Set of adjustable mounting clips ● Warranty information ● Instruction manual Premium Safety Features ● Features an illuminated, rocker-style power switch with a locking, transparent guard to prevent accidental turn offs ● An integral, 15-amp resettable circuit breaker prevents dangerous circuit overloads that can irreversibly damage connected equipment Rugged, Durable Housing ● A rugged, all-metal housing is durably constructed making it a great solution for industrial applications ● An attractive gray housing with stylish black receptacles match the decor of most professional settings Specifications OVERVIEW UPC Code 037332186430 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output (Watts) 1800 Output Receptacles (8) 5-15R Circuit Breaker (amps) 15 Outlet Spacing 5.28-in. center-to-center spacing USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) No Switches Combination AC circuit breaker and lighted 2-position power switch controls power to all outlets Locking Switch Cover Transparent locking switch cover 2/4 SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1650 UL1449 Let Through Rating 500V UL verified EMI / RFI Filtering Yes Automatic Shut-Off No DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Power Cord Color Black Housing Color Silver Included Mounting Accessories Set of adjustable mounting clamps Mounting Holes or Slots No Outlets Measurement (Center to Center) 5.28 Receptacle Color Black Shipping Dimensions (hwd / in.) 2.40 x 3.40 x 51.90 Shipping Dimensions (hwd / cm) 6.10 x 8.64 x 131.83 Shipping Weight (lbs.) 3.30 Shipping Weight (kg) 1.50 Unit Dimensions (hwd / in.) 1.250 x 1.620 x 48.000 Unit Dimensions (hwd / cm) 3.18 x 4.11 x 121.9 Unit Weight (lbs.) 2.64 Unit Weight (kg) 1.20 Outlet Spacing 5.28-in. center-to-center spacing FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS 3/4 WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
SS480806
物料型号:SS480806 器件简介:8位电源插座,带浪涌保护,6英尺(1.83米)线长,1650焦耳,48英寸长度。
引脚分配:8个NEMA 5-15R插座,中心距为5.28英寸。
参数特性:1800W,120V,15A,带有可复位的电路断路器,以防止电路过载。
功能详解:提供多插座120V电源分配和浪涌保护,适用于空间有限的场所。
内置浪涌保护器,无需单独的桌面单元,节省安装新插座的时间和成本。
适用于电信、计算机或互联网络设备的分支电路电源分配。
应用信息:适用于计算机房、工作台、修理店、实验室或任何需要将许多电气设备同时连接到单个交流墙壁插座的地方。
封装信息:坚固耐用的全金属外壳,灰色外壳与大多数专业环境的装饰相匹配。
包括一套可调节的安装夹。
SS480806 价格&库存
很抱歉,暂时无法提供与“SS480806”相匹配的价格&库存,您可以联系我们找货
