PSF3612
PSF3612
    TRIPPLITE
    POWER STRIP 36" 12OUT 15'CORD
PSF3612 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 12-Outlet Foldable Power Strip with 2 Pivots, 120V, 12A, 15 ft. (4.57 m) Cord, 5-15P, 36 in. MODEL NUMBER: PSF3612 Highlights ● Foldable, dual pivot 36-in mountable housing ● 12 standard NEMA 5-15R outlets and a 15-ft. (4.57 m) power cord ● Lighted, covered On/Off switch and 12-amp circuit breaker ● Sturdy construction and heavyduty, all-metal housing Package Includes Foldable design is ideal for using around corners and tight spaces, by multiple users, or anywhere you need a flexible power strip that can fold in half to accommodate multiple environments. Description The PSF3612 provides a 12-amp, 120v power strip with 12 standard NEMA 5-15 outlets in a rugged, allmetal, mountable housing that folds in the middle. It allows for both vertical and horizontal mounting with additional mounting clips to ensure the pivots stay in place. The PSF3612 is ideal for a variety of uses including office, rack-mount, workbench, industrial and telecom applications. With a NEMA 5-15P, 15-ft. (4.57 m) power cord, you don't have to install it next to outlets you already have; it can be mounted across the room and deliver reliable power where you need it most. With foldable dual pivots, the PSF3612 can go around corners, be used by more than 1 person, and fit in smaller spaces. A lighted and covered On/Off switch helps prevent accidental shut-offs, while a 15-amp circuit breaker guards against dangerous circuit overloads. Its sturdy all-metal extruded aluminum housing stands up to demanding network, laboratory or factory environments. Features Multi-Outlet, Foldable Power Distribution Vertical or Horizontal Moun Extra Long Power Cord Premium Safety Features Heavy-Duty Housing Specifications OVERVIEW 1/3 ● PSF3612 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States UPC Code 037332187949 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (12) 5-15R Circuit Breaker (amps) 12 Transformer Accommodation (6) Yes Right-Angle Outlets No Outlet Spacing 1.18-in. 1st segment; 2.0-in. 2nd segment; 2.25-in. 3rd segment USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports vertical or horizontal mounting in rack enclosures, raceways and a variety of other applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Receptacle Color Black Shipping Dimensions (hwd / in.) 2.40 x 4.60 x 41.20 Shipping Dimensions (hwd / cm) 6.10 x 11.68 x 104.65 Shipping Weight (lbs.) 4.40 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (kg) 2.00 Unit Dimensions (hwd / in.) 1.770 x 1.690 x 37.240 Unit Dimensions (hwd / cm) 4.50 x 4.29 x 94.60 Unit Weight (lbs.) 1.64 Unit Weight (kg) 0.74 Outlet Spacing 1.18-in. 1st segment; 2.0-in. 2nd segment; 2.25-in. 3rd segment FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 60950-1; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PSF3612
物料型号为PSF3612,这是一款12位插座的可折叠式电源条,具有两个铰链,支持120V、12A的电压和电流,带有15英尺(4.57米)的电源线和5-15P插头。
它拥有稳固的结构和重型全金属外壳,适用于办公、机架安装、工作台、工业和电信等多种应用场景。
引脚分配包括12个标准的NEMA 5-15R插座,适合多种设备使用。
参数特性包括: - 额定输入电压:120V AC - 推荐电气服务:15A 120V - 输入线规格:14号SJT - 频率兼容性:50/60Hz - 带有12安培的电路断路器
功能详解: - 电源条可以垂直或水平安装,具有额外的安装夹以确保铰链固定。
- 设计有折叠式双铰链,可适应转角、多人使用或较小空间。
- 电源条带有照明和带盖的开/关开关,以防止意外关闭,同时带有15安培的电路断路器,以防止危险的电路过载。
应用信息: - 电源条适用于需要灵活电源分配的场合,如办公室、机架、工作台、工业和电信应用。
封装信息: - 颜色:银色 - 材质:铝 - 电源线颜色:黑色 - 形式因素支持:支持在机架外壳、电缆桥架和其他多种应用中垂直或水平安装 - 外壳颜色:银色 - 包含的安装配件:包括安装夹 - 发货尺寸和重量也在文档中提供。
此外,该产品符合cUL Listed:UL 60950-1;UL Listed标准,遵守RoHS规定,并提供终身有限保修。
PSF3612 价格&库存
很抱歉,暂时无法提供与“PSF3612”相匹配的价格&库存,您可以联系我们找货
