TLM812GF
TLM812GF
    TRIPPLITE
    POWER STRIP 8OUT 12'CORD
TLM812GF 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power It! 8-Outlet Safety Power Strip, 12 ft. (3.66 m) Cord with GFCI Plug MODEL NUMBER: TLM812GF Highlights ● 8 outlets (including transformer outlets and 4 safety covers) ● 12-ft. (3.66 m) cord with GFCI plug ● Cord wrap with hang holes ● Rugged metal case Package Includes Description This Tripp Lite power strip is designed to safely distribute power to connected equipment in harsh environments. It provides a convenient source for multiple outlets wherever they're needed. 8 outlets distribute AC power to a wide range of power tools, pumps, machinery, air compressors and more. Convenient transformer outlets accommodate multiple transformers without blocking other outlets. A 12-ft. (3.66 m) grounded cord with integrated cord clip reaches distant outlets. A GFCI plug protects users from electrical shock in wet or humid environments. A lighted on/off switch provides power control over connected equipment. 4 safety covers shield unused outlets from debris and accidental contact. A rugged metal case stands up to the harshest environments. Built-in cord wrap with hang holes provides convenient cord management. Integrated keyhole slots on bottom panel provide convenient wall/desk mounting. Its bright yellow color alerts you and others that power cords and tools are in use. Features ● 8 outlets distribute AC power to a wide range of power tools, pumps, machinery, air compressors and more. ● Convenient transformer outlets accommodate multiple transformers without blocking other outlets. ● A 12-ft. (3.66 m) grounded cord with integrated cord clip reaches distant outlets. ● A GFCI plug protects users from electrical shock in wet or humid environments. ● A lighted on/off switch with integrated 15 amp circuit breaker provides power control and overload protection over connected equipment. ● 4 safety covers shield unused outlets from debris and accidental contact. ● A rugged metal case stands up to the harshest environments. ● Built-in cord wrap with hang holes provides convenient cord management. ● Integrated keyhole slots on bottom panel provide convenient wall/desk mounting. ● Its bright yellow color alerts you and others that power cords and tools are in use. ● OSHA color guidelines, outlined in Document 1910.145, alert users to hazardous situations, which may cause minor or moderate injury. This Tripp Lite product complies with those guidelines. Specifications 1/3 ● TLM812GF Safety Power Strip ● 4 safety covers ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332140135 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 12 Right-Angle Plug No Input Cord Length (m) 3.66 Integrated Cord Clip Yes OUTPUT Frequency Compatibility 60 Hz Output Receptacles (8) 5-15R Circuit Breaker (amps) 15 Overload Protection GFCI plug Transformer Accommodation (6) Yes Outlet Orientation 1 bank of 5, 1 bank of 3 (transformer outlets) Right-Angle Outlets Yes Outlet Safety Covers Detail Includes 4 outlet safety covers USER INTERFACE, ALERTS & CONTROLS Switches Combination AC circuit breaker and 2 position red illuminated on/off power switch PHYSICAL Color Yellow; Black Material of Construction Metal Power Cord Color Yellow Housing Color Yellow; Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) 145mm Outlets Measurement (Center to Center) Distance between standard outlets = 1 in.; Distance between transformer outlets = 2 in. 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Receptacle Color Black Shipping Dimensions (hwd / in.) 2.50 x 10.00 x 14.80 Shipping Dimensions (hwd / cm) 6.35 x 25.40 x 37.59 Shipping Weight (lbs.) 3.60 Shipping Weight (kg) 1.63 Unit Dimensions (hwd / in.) 10.260 x 5.130 x 1.570 Unit Dimensions (hwd / cm) 26.06 x 13.03 x 3.99 Unit Weight (lbs.) 4.63 Unit Weight (kg) 2.10 FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
TLM812GF 价格&库存
很抱歉,暂时无法提供与“TLM812GF”相匹配的价格&库存,您可以联系我们找货
