EPS-618121
EPS-618121
    CHIPQUIK
    POWER STRIP 72" 18 BLACK OUTLET
EPS-618121 数据手册
EPS-618121 Datasheet revision 1.0 www.chipquik.com 72” Metal Power Strip with 18 Outlets, Surge Protected Specifications Power Strip Measurement: L72" x W1.653" x H1.496" (1829 x 42 x 38mm)* Outlets: 18 Outlet Color: Black Outlet Orientation: Horizontal Plug / Receptacle Type: NEMA 5-15P / 5-15R Outlet Spacing: 3-3/4" (98mm) (center to center) Power Cord: 12' (3.66m) 14/3 AWG, SJT Heavy Duty Voltage Input/Output: 110-125V 60Hz Current Input: 15A Full Load: 1875VA On/Off Switch: Yes (lighted) Circuit Breaker: Resettable (built in the switch) Surge Protection: Up to 400 Joules Lines Protected: (L-N) (L-G) (N-G) Response time: Less than 5 nanosecond Noise Filter: EMI/RFI Mounting on Back: Yes Mounting Tabs: On both ends (5/8") Mounting Clips: 3/4" (19mm) Spring Steel Clips included Indicator: N/A Notes * Measurement is approximate. For installation purposes: The length of the power strip does not include the mounting tabs (approx. 0.624"/15.8mm on both ends), if any; the width does not include the size of screws (min. 0.064"/1.6mm on each side); the height does not include the receptacles (about 0.208"/5.3mm above the surface of the strip). For use in countries and regions with 110-125V 60Hz only. Not intended for use in or around wet or potentially wet areas. 1 © 1994-2015 Chip Quik® Inc.
EPS-618121 价格&库存
很抱歉,暂时无法提供与“EPS-618121”相匹配的价格&库存,您可以联系我们找货
