PS-415-HG
PS-415-HG
    TRIPPLITE
    POWER STRIP 8.65 15A 4OUT 15'
PS-415-HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Highlights Product Use in your Country or Municipality ● Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew ● Complies with UL 1363 specifications ● 15 ft. (4.6 m) cord with NEMA 515P-HG hospital-grade plug ● Features 4 NEMA 5-15R-HG hospital-grade outlets Tripp Lite Healthcare Product Specialist Safe-IT Medical-Grade Power Strip, UL 1363, 4 Hospital-Grade Outlets, Antimicrobial, 15 ft. (4.57 m) Cord MODEL NUMBER: PS-415-HG Package Includes Medical-grade power strip with patented antimicrobial coating and long 15 ft. cord provides safe, versatile power distribution. Description The PS-415-HG Medical-Grade Power Strip supplies power outside of patient-care vicinities, such as administrative areas or in resident rooms of long-term care facilities that do not use line-operated electrical equipment for diagnostic, treatment or monitoring purposes. Compliant with UL 1363 specifications, this 120V, 50/60 Hz power strip features a NEMA 5-15P-HG hospital-grade plug and four NEMA 5-15R-HG hospital-grade outlets. The power strip is protected by a antimicrobial powder coating. Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew. The coating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products. A built-in resettable 15A circuit breaker controls power to all outlets and protects the power strip against overloads. Switchless design prevents the unit from being accidentally shut off. The 15-foot (4.6 m) cord provides ample reach to a power source. Keyhole mounting tabs and flanges make installing this power strip easy. The all-metal housing ensures safety and is guaranteed to last a long time in demanding surroundings. Features Power Distribution Outside of Patient-Care VicinitiesIdeal for use in administrative areas and resident rooms with no line-operated electrical equipment for diagnostic, treatment or monitoring purposes120V, 50/60 Hz power strip complies with UL 1363 specifications Exclusive Antimicrobial ProtectionAntimicrobial coating helps resist the growth of bacteria, viruses, fungi, mold and mildewCoating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products. Versatile Medical-Grade Solution4 NEMA 5-15R-HG hospital-grade outlets provide consistent powerRugged, all-metal housing for long life in demanding environments 1/3 ● PS-415-HG UL 1363 MedicalGrade Power Strip with four 15A Hospital-Grade Outlets and 15ft. (4.57 m) Cord ● Owner's Manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Premium Safety FeaturesResettable 15A circuit breaker protects against dangerous overloadsSwitchless design prevents accidental shut-off Ready to Use Right Out of the BoxBuilt-in keyhole mounting tabs and flanges make the PS-415-HG easy to install on a variety of surfaces Specifications OVERVIEW UPC Code 037332118479 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Plug Features Hospital Grade Plug Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P-HG Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (4) 5-15R-HG Circuit Breaker (amps) 15 Overload Protection 15A circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 4 Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Switches No power switch PHYSICAL Color White Material of Construction Metal Power Cord Color White 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Housing Color White Included Mounting Accessories Keyhole mounting tabs and flanges Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between keyhole tabs = 127mm; Distance between end tabs = 207.45mm Outlets Measurement (Center to Center) Inner outlets = 1.27 in. Receptacle Color White Shipping Dimensions (hwd / in.) 2.40 x 5.90 x 10.00 Shipping Dimensions (hwd / cm) 6.10 x 14.99 x 25.40 Shipping Weight (lbs.) 3.00 Shipping Weight (kg) 1.36 Unit Dimensions (hwd / in.) 2.000 x 5.500 x 10.000 Unit Dimensions (hwd / cm) 3.8 x 21.9 x 6.4 Mounting Details Includes flanges FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial Yes Built-In Circuit Breaker Yes Antibacterial No Built-in Cable Management No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS-415-HG 价格&库存
很抱歉,暂时无法提供与“PS-415-HG”相匹配的价格&库存,您可以联系我们找货
