PS-615-HG
PS-615-HG
    TRIPPLITE
    POWERSTRIP120V6OUTHOSPGRADE
PS-615-HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Standards that govern use of this product vary by country and sometimes municipality. In the United States, this product is not for use in the Patient Care Vicinity, as defined in the National Electric Code Highlights ● UL 1363 power strip for use outside patient care vicinities ● Antimicrobial protection helps prevent the growth of bacteria, viruses, fungi, mold and mildew ● NEMA 5-15P-HG plug permits connection in confined or hardto-reach spaces ● 15 ft. (4.6 m) power cord allows flexibility in placing power strip in relationship to AC outlet ● Switchless design helps prevent accidental shutdown of essential equipment (NEC). This product is approved to CSA C22.2/CuL standards and approved for use in Canada. For application guidance and product selection in your country, please consult a Tripp Lite Healthcare Product Specialist or your own expert. Safe-IT UL 1363 Medical-Grade Power Strip, 6x Hospital-Grade Outlets, Antimicrobial, 15 ft. (4.57 m) Cord MODEL NUMBER: PS-615-HG Applications Supply safe medical-grade power to lab, imaging and other electric components outside a patient care area Package Includes Delivers power to devices outside of patient care vicinities, including therapy rooms and administrative areas. Features 6-Outlet Power Strip Supplies Power Outside Patient Care VicinitiesThis medical-grade power strip is for administrative areas or resident rooms of long-term care facilities that do not use line-operated electrical equipment for diagnostic, treatment or monitoring purposes. This includes operating rooms, therapy rooms, imaging environments and administrative areas. With six NEMA 5-15R-HG outlets and a 15-foot (4.6-meter) power cord with NEMA 5-15P-HG plug, this 120V power strip complies with UL 1363. Exclusive Antimicrobial Protection Fights Healthcare-Acquired Infections (HAIs)The PS-615-HG is protected by a patented antimicrobial powder coating with EPA-registered and FDA-compliant silver ionic technology. The antimicrobial surface protection is 99.9 percent effective in inhibiting the growth of bacteria and reducing the risk of HAIs in hospitals and other medical environments. The coating meets the requirements of JIS Z 2801:2000, an international standard for evaluating efficacy in antimicrobial products. Premium Safety Features Help Ensure Proper Power ConnectionsWith no central power switch, the PS-615-HG presents no danger of accidental shutoff and cutting off power to essential devices. One resettable 15-amp circuit breaker shuts down all input if the connected load draws too much power. Ready for Installation Straight from the BoxBuilt-in mounting flanges and integrated keyhole slots let you install the durable metal housing on any wall or other flat surface for distributing immediate power to equipment outside a patient care vicinity. Specifications 1/3 ● PS-615-HG Medical-Grade Power Strip ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332100108 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V Input Plug Features Hospital Grade Plug Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P-HG Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R-HG Circuit Breaker (amps) 15 Overload Protection 15A circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Switches No power switch PHYSICAL Color White Material of Construction Metal Power Cord Color White Housing Color White Included Mounting Accessories Keyhole mounting tabs and flanges Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between keyhole slots = 261.92mm; Distance between end tabs = 330.17mm Outlets Measurement (Center to Center) 1.52 in. 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Receptacle Color White Shipping Dimensions (hwd / in.) 2.00 x 5.80 x 14.10 Shipping Dimensions (hwd / cm) 5.08 x 14.73 x 35.81 Shipping Weight (lbs.) 3.30 Shipping Weight (kg) 1.50 Unit Dimensions (hwd / in.) 1.500 x 13.750 x 2.500 Unit Dimensions (hwd / cm) 3.8 x 34.9 x 6.4 Mounting Details Includes flanges FEATURES & SPECIFICATIONS Antimicrobial Yes Built-In Circuit Breaker Yes Antibacterial No Built-in Cable Management No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS-615-HG 价格&库存
很抱歉,暂时无法提供与“PS-615-HG”相匹配的价格&库存,您可以联系我们找货
PS-615-HG
    库存:4
