1000 Eaton Boulevard
Cleveland, OH 44122
United States
Protect It! 7-Outlet Surge Protector, 12 ft. (3.66
m) Cord, 1080 Joules, Fax/Modem Protection,
RJ11
MODEL NUMBER: SUPER6TEL12
Highlights
7 outlets / 12-ft. (3.66 m) cord
1080 joule rating
Modem/fax surge protection
Package Includes
Description
Tripp Lite's SUPER6TEL12 surge suppressor offers complete AC and phone line surge suppression for
comprehensive protection of workstations, desktop PCs, telecom systems and other sensitive electronics.
High-grade AC surge suppression shields connected equipment from damage and performance problems
due to transient surges. Set of RJ11 telephone line suppression jacks protect dialup and DSL modem
lines, fax machines, cordless phones and more. SUPER6TEL12 offers 7 total outlets, 12-ft. (3.66 m) cord
with a space-saving right-angle plug and diagnostic LEDs to warn of wiring problems and suppressor
damage. Heavy grade AC suppression rated at 1080 joules shields equipment from surges and line noise.
Attractive white suppressor housing with keyhole mounting tabs and 3 designated transformer plug outlets
offers convenient protection of desktop computer equipment and accessories. $50,000 Ultimate Lifetime
Insurance (U.S., Canada, and Puerto Rico only).
PLUG/OUTLETS: Input: NEMA5-15P/Output: 7 NEMA5-15R/12-ft. (3.66 m) AC line cord
ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires NEMA5-15R wall receptacle)
FORMAT: Corded multi-outlet strip with 3 transformer spaced outlets
SUPPRESSION: AC: 150V RMS Clamping/1080 joules/330V UL1449 Let-through Rating Phone: Single
telephone line surge suppression (RJ11 jacks, 2 wire, 1 line)
Features
1080 joules AC surge suppression shields equipment from the strongest surges and line noise
7 AC outlets with room for 3 transformer plugs without blocking outlets covers computers and all
peripherals
Phone line surge suppression protects both dialup and DSL modems, plus fax machines, cordless
phones and more (pair of RJ11 jacks, 2 wire, 1 line, includes 6-ft (1.83 m) phone cable)
12-ft. (3.66 m) cord with a space-saving right angle plug
Built-in power switch and 15 amp circuit breaker offers power control and overload protection over all
outlets
Fail-safe thermal fusing protects against fire and other damage in the event of an extreme, extended
overvoltage or surge condition
Diagnostic LEDs confirm outlet grounding and surge suppression status
UL1449 3rd Edition Rated (330V all modes), UL1363 (Power Tap), UL497A (Communications), Meets
FCC part 68 rules, cUL (Canada)
1/4
SUPER6TEL12 Surge
Suppressor
6-ft. (1.83 m) telephone cord
Instruction manual with warranty
information
Cleveland, OH 44122
United States
Exceeds IEEE 587 category A & B surge suppression specifications
$50,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only)
Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing
equipment damage and indicating replacement is required
Specifications
OVERVIEW
UPC Code
037332097392
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Plug Features
Right Angle (36D)
Input Cord Gauge Type
14 gauge; SJT
Input Cord Gauge (AWG)
14
Voltage Compatibility (VAC)
120
Maximum Surge Amps
72000
Input Plug Type
NEMA 5-15P
Input Cord Details
SJT
Input Cord Length (ft.)
12
Right-Angle Plug
Yes
Input Cord Length (m)
3.66
Integrated Cord Clip
No
OUTPUT
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(7) 5-15R
Circuit Breaker (amps)
15
Transformer Accommodation
(4) Yes
Outlet Orientation
Single row of 5, plus 2 side mounted outlets
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
Switches
Two position on/off power switch
Diagnostic LED Details
Built-in LED confirms suppressor "protection present" (green) status
2/4
Cleveland, OH 44122
United States
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
1080
AC Suppression Response Time
< 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression
UL1449 Let Through Rating
330V - UL Verified
EMI / RFI Filtering
Up to 20 dB
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Telephone/DSL Protection Details
1 line
Cable (Coax) Protection
No
Network (Ethernet) Protection
No
Yes
PHYSICAL
Material of Construction
Plastic
Power Cord Color
Gray
Housing Color
Light Gray
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
Distance between slots = 70 mm; Distance between slot height = 24 mm
Outlets Measurement (Center to
Center)
Between Standard Outlets = 29mm; Between Transformer Outlets = 48mm
Receptacle Color
Gray
Shipping Dimensions (hwd / in.)
12.40 x 1.88 x 7.20
Shipping Dimensions (hwd / cm)
31.50 x 4.78 x 18.29
Shipping Weight (lbs.)
2.10
Shipping Weight (kg)
0.95
Unit Dimensions (hwd / in.)
1.540 x 2.720 x 10.300
Unit Dimensions (hwd / cm)
3.91 x 6.91 x 26.16
Unit Weight (lbs.)
1.82
Unit Weight (kg)
0.83
Input Cord Color
White
FEATURES & SPECIFICATIONS
Antimicrobial
No
Rotatable Outlets
No
3/4
Cleveland, OH 44122
United States
STANDARDS & COMPLIANCE
Industry Canada (Communications)
Industry Canada
Product Certifications
CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL
1363; UL Listed
Product Compliance
FCC Part 68; RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“SUPER6TEL12”相匹配的价格&库存,您可以联系我们找货
