TLP1208TEL
TLP1208TEL
    TRIPPLITE
    SURGE PROTECTOR 12 OUTLET 8FT
TLP1208TEL 数据手册
Protect It! 12-Outlet Surge Protector, 8 ft. (2.43 m) Cord, 2160 Joules, Tel/Modem Protection MODEL NUMBER: TLP1208TEL Highlights ● 12 outlets / 8-ft. (2.43 m) cord ● 2160 joule rating ● 1 in/2 out tel/modem surge protection ● 4 transformer spaces Package Includes Description Tripp Lite's TLP1208TEL offers economical AC surge suppression for protection of workstations, PCs, telecom systems, home electronics and other sensitive equipment. The TLP1208TEL features 12 outlets, an 8-ft. (2.43 m) cord with a space-saving right-angle plug, and diagnostic LEDs to warn of suppressor damage. The unit has a surge suppression rating of 2160 joules to shield equipment from line noise and the strongest surges. Built-in RJ11 jacks prevent surges from damaging your modem/fax/phone equipment. $150,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) PLUG/OUTLETS: Input: NEMA5-15P/Output: 12 NEMA5-15R/8-ft. (2.43 m) AC line cord ELECTRICAL: 120V AC, 50/60Hz, 15A (requires NEMA5-15R wall receptacle) FORMAT: Corded multi-outlet strip with 4 transformer-spaced outlet SUPPRESSION: AC: 150V RMS Clamping/2160 joules/330V L-G, 400V L-N, 400V N-G UL1449 3rd Edition Features ● 12 outlets with integrated child safety covers ● 8-ft. (2.43 m) cord with space-saving right-angle plug ● Built-in RJ11 jacks prevent surges from damaging your modem/fax equipment; 6-ft. (1.83 m) telephone cord included ● Surge suppression rating: 2160 joules ● EMI/RFI noise filtering ● 15 amp resettable circuit breaker ● Diagnostic LEDs confirm suppressor "protection present" (green) and "grounded" (red) status ● Includes full normal mode (H-N) and common mode (N-G/H-G) line surge suppression ● Can accommodate up to 4 transformers without blocking remaining outlets ● Keyhole supports for wall mounting ● $150,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) covers connected equipment ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required 1/4 ● TLP1208TEL surge suppressor ● 6-ft. (1.83 m) RJ11 telephone cord ● Instruction manual with warranty information Specifications OVERVIEW UPC Code 037332152503 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Plug Features Right Angle (36D) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 144000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 8 Right-Angle Plug Yes Input Cord Length (m) 2.44 Integrated Cord Clip No OUTPUT Output Volt Amp Capacity (VA) 15 Output Watt Capacity (Watts) 1875 Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (12) 5-15R Overload Protection 15A resettable circuit breaker Transformer Accommodation (8) Yes Outlet Orientation Two rows of outlets, including 4 widely spaced for transformers Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Two-position on/off power switch Diagnostic LED Details Built-in LEDs confirm suppressor "protection present" (green) and "grounded" (red) status SURGE / NOISE SUPPRESSION 2/4 AC Suppression Joule Rating 2160 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 330V L-G, 400V L-N, 400V N-G EMI / RFI Filtering Up to 40 dB Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Telephone/DSL Protection Details 1 line Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection Yes PHYSICAL Material of Construction Plastic Power Cord Color Black Housing Color Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between horizontal tabs = 152 mm; Distance between vertical tabs = 73.5 mm Outlets Measurement (Center to Center) Distance between standard outlets = 25.4mm; Distance between transformer outlets = 57mm Receptacle Color Black Shipping Dimensions (hwd / in.) 13.60 x 2.40 x 8.80 Shipping Dimensions (hwd / cm) 34.54 x 6.10 x 22.35 Shipping Weight (lbs.) 2.50 Shipping Weight (kg) 1.13 Unit Dimensions (hwd / in.) 1.54 x 2.72 x 10.30 Unit Dimensions (hwd / cm) 3.91 x 6.91 x 26.16 Unit Weight (lbs.) 2.09 Unit Weight (kg) 0.95 Input Cord Color Black FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE 3/4 Industry Canada (Communications) Industry Canada Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 1363; UL Listed Product Compliance FCC Part 68; RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $150,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 4/4
TLP1208TEL 价格&库存
很抱歉,暂时无法提供与“TLP1208TEL”相匹配的价格&库存,您可以联系我们找货
