TLP4BK
TLP4BK
    TRIPPLITE
    SURGE PROTECT WALLMOUNT 4 OUTLET
TLP4BK 数据手册
Protect It! Surge Protector with 4 Side-Mounted Outlets , Direct Plug-In, 720 Joules MODEL NUMBER: TLP4BK Highlights ● 4 side-mounted outlets (including 2 transformer-friendly outlets) ● Direct plug-in design ● 720 joule rating ● Diagnostic LEDs Package Includes Description The TLP4BK Surge Suppressor from Tripp Lite has 4 side-mounted outlets (including 2 transformerfriendly outlets), a convenient direct plug-in design and diagnostic LEDs. The unit has a surge suppression rating of 720 joules to handle the strongest surges. $10,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● 4 side-mounted outlets allows easier plug connection and removal (including 2 transformer-friendly outlets) ● Direct plug-in design converts two outlets into four by plugging in to any wall outlet ● Surge suppression rating: 720 joules ● EMI/RFI noise filtering ● Diagnostic LEDs indicate protection present & ground present ● $10,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) covers connected equipment ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications OVERVIEW UPC Code 037332138392 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Length Details Direct plug-in 1/3 ● TLP4BK Surge Suppressor ● Instruction manual with warranty information Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 0 Right-Angle Plug No Input Cord Length (m) 0.00 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output (Watts) 1800 Output Receptacles (4) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Outlet Orientation Side-mounted Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Diagnostic LED Details Built-in LEDs confirm suppressor "protection" (green) and "grounded" (red) status SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 720 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 500V EMI / RFI Filtering Up to 20 dB Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Housing Color Black 2/3 Mounting Holes or Slots No Receptacle Color Black Shipping Dimensions (hwd / in.) 6.70 x 1.50 x 2.80 Shipping Dimensions (hwd / cm) 17.02 x 3.81 x 7.11 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 Unit Dimensions (hwd / in.) 5.00 x 2.20 x 1.60 Unit Dimensions (hwd / cm) 12.7 x 5.59 x 4.06 Unit Weight (lbs.) 0.36 Unit Weight (kg) 0.16 FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Industry Canada (Communications) No Product Certifications cUL Listed; UL 1449; UL Listed Product Compliance RoHS WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $10,000 Ultimate Lifetime Insurance  © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
TLP4BK 价格&库存
很抱歉,暂时无法提供与“TLP4BK”相匹配的价格&库存,您可以联系我们找货
