1581T5
1581T5
    HAMMONDMANUFACTURING
    POWER STRP 11.75"10A 230VAC 5OUT
1581T5 数据手册
International (IEC) - Industrial/Commercial Grade 1581 Series Outlet Strips Key Features • Designed for use with IEC power cords • All metal housing – tough extruded aluminum case with black powder-coated steel cover • One IEC 320 - C14 inlet, and 4, 5, 6 or 8 IEC 320 - C13 outlets • On-Off switch is rocker type with green light (on those units with on-off switch - listed below) or a green pilot light to indicate power on. • Mounting feet (with keyhole slots) allow temporary work station mounting if desired. • Includes 10A, 230VAC circuit breaker to prevent accidental line overload • cULus listed, Standards UL60950 & CSA C22.2 No. 60950 • CSA certified, Standards C22.2 (No. 21-95 and No. 42-99) • TÜV-GS certified, Standards EN60335-1 and EN60950-1 • CE certified Registration #: AN 72031916 0001 8 Part No. Outlets 1581H4 1581H5 1581H6 1581H8 1581T4 1581T5 1581T6 1581T8 4 5 6 8 4 5 6 8 On-Off Switch Yes Yes Yes Yes - Pilot Light Yes Yes Yes Yes Dimensions (inches) 10 x 2 x 2 11.75 x 2 x 2 13.25 x 2 x 2 17 x 2 x 2 10 x 2 x 2 11.75 x 2 x 2 13.25 x 2 x 2 17 x 2 x 2 www.hammondmfg.com Electrical Rating Ship Wt. 230VAC / 10A 230VAC / 10A 230VAC / 10A 230VAC / 10A 230VAC / 10A 230VAC / 10A 230VAC / 10A 230VAC / 10A 1.2 lbs 1.2 lbs 1.5 lbs 2.0 lbs 1.2 lbs 1.2 lbs 1.5 lbs 2.0 lbs
1581T5 价格&库存
很抱歉,暂时无法提供与“1581T5”相匹配的价格&库存,您可以联系我们找货
1581T5
    库存:187
