SK30USB
SK30USB
    TRIPPLITE
    SURGE3OUTLET120VUSBCHARGER
SK30USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 3-Outlet Surge Protector, Direct PlugIn, 540 Joules, 2.1 A USB Charger, Diagnostic LED MODEL NUMBER: SK30USB Highlights ● 3 outlets/direct plug-in ● 540 joule rating ● 2.1 amp USB charging ● Diagnostic LED Package Includes ● Description The SK30USB surge suppressor offers reliable surge and line noise protection. The compact direct plugin design allows for easy portability and features 3 outlets and 540 joules of surge energy absorption. Diagnostic LED alerts you to potential wiring or protection faults before connected equipment is damaged. 2.1 amp USB charging ports offer fast charging for smartphones, tablets, MP3 players and other portable devices. $5,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Features ● 3 outlets / direct plug-in ● Surge suppression rating: 540 joules ● 2.1 amp USB Charger ● EMI/RFI noise filtering ● Diagnostic LED indicates Protected (green) ● $5,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications OVERVIEW UPC Code 037332180353 Product Type Surge Protector Charging Form Factor Strip Device Compatibility Phone; Tablet; Amazon Kindle 1/4 SK30USB surge suppressor 1000 Eaton Boulevard Cleveland, OH 44122 United States INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V Input Cord Length Details Direct Plug-In Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 0 Right-Angle Plug No Input Cord Length (m) 0.00 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (3) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (2) Yes Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes CHARGING Number of Charging Ports 2 Total Charging Watts 10.5 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (2) 2.1A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 540 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression AC Suppression Surge Current Rating 27,000 UL1449 Let Through Rating 500, 400, 500 EMI / RFI Filtering Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Immunity Conforms to IEE 587/ANSI C62.41 Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Black Mounting Holes or Slots No Receptacle Color Black Shipping Dimensions (hwd / in.) 6.30 x 2.70 x 4.00 Shipping Dimensions (hwd / cm) 16.00 x 6.86 x 10.16 Shipping Weight (lbs.) 0.60 Shipping Weight (kg) 0.27 Unit Dimensions (hwd / in.) 5.280 x 3.740 x 1.180 Unit Dimensions (hwd / cm) 13.40 x 9.50 x 3.00 Unit Weight (lbs.) 0.41 Unit Weight (kg) 0.19 Input Cord Color Black FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 42 (Canada); NOM (Mexico); UL 1449; UL 497A Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $5,000 Ultimate Lifetime Insurance  3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
SK30USB
物料型号: - 型号编号:SK30USB
器件简介: - SK30USB浪涌保护器提供可靠的浪涌和线路噪声保护。紧凑的直接插入式设计便于携带,具有3个插座和540焦耳的浪涌能量吸收能力。诊断LED可在连接设备损坏前提醒您潜在的接线或保护故障。3.4安培的USB充电端口为智能手机、平板电脑、MP3播放器和其他便携设备提供快速充电。提供5000美元的终极终身保险(仅限美国、加拿大和波多黎各)。
引脚分配: - 输入:NEMA 5-15P - 输出:3个5-15R插座
参数特性: - 额定输入电压:120V AC - 频率兼容性:60 Hz - 电路断路器:15安培 - AC抑制焦耳等级:540焦耳 - AC抑制响应时间:<1纳秒 - EMI/RFI滤波:是 - 自动关闭:如果保护电路失效,则永久切断插座的电源,防止设备损坏,并提示需要更换
功能详解: - 3个插座/直接插入 - 浪涌抑制等级:540焦耳 - 3.4安培USB充电器 - EMI/RFI噪声滤波 - 诊断LED显示保护状态(绿色) - 自动关闭功能
应用信息: - 设备兼容性:手机、平板电脑、亚马逊Kindle
封装信息: - 材料:塑料 - 外壳颜色:黑色 - 插座颜色:黑色 - 单位尺寸:5.280 x 3.740 x 1.180英寸 - 单位重量:0.41磅
SK30USB 价格&库存
很抱歉,暂时无法提供与“SK30USB”相匹配的价格&库存,您可以联系我们找货
