TLP74R
TLP74R
    TRIPPLITE
    SURGE SUPPRESSOR 7 OUT 4' RA
TLP74R 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 7-Outlet Surge Protector, 4 ft. (1.22 m) Cord, 1080 Joules, 1 Diagnostic LED, Light Gray Housing MODEL NUMBER: TLP74R Highlights ● 7 outlets (6 right-angle outlets and 1 designated transformer outlet) ● 4-ft. (1.22 m) cord ● 1080 joule rating Package Includes ● Description Tripp Lite's TLP74R offers economical AC surge suppression for protection of workstations, desktop PCs, telecom systems and other sensitive electronics. Built-in AC surge suppression shields connected equipment from damage and performance problems due to transient surges. TLP74R offers 7 total outlets (6 at right angle and 1 designated transformer plug outlet), 4-ft. (1.22 m) cord and diagnostic LED to warn of suppressor damage. AC suppression rated at 1080 joules shields equipment from surges and line noise. Attractive gray housing with keyhole mounting tabs offering convenient protection of desktop computer equipment and accessories. $25,000 Ultimate Lifetime Insurance (USA & Canada Only). PLUG/OUTLETS: Input: NEMA5-15P/Output: 7 NEMA5-15R/4-ft. (1.22 m) AC line cord ELECTRICAL: 120V AC, 60Hz, 15A (Requires NEMA5-15R wall receptacle) FORMAT: Corded multi-outlet strip SUPPRESSION: AC: 150V RMS Clamping/1080 joules/400V UL1449 Let-through Features ● 1080 joules AC surge suppression shields equipment from the strongest surges and line noise ● 7 total AC outlets (6 right angle and 1 transformer plug outlet) ● 4-ft. (1.22 m) AC line cable ● Lighted on/off switch with integrated circuit breaker for overload protection of all outlets ● Diagnostic LED confirms surge suppression status ● Integrated keyhole slots provide convenient wall/desk mounting ● UL1449 3rd Edition Rated (400V all modes), UL1363 (Power Tap), cUL (Canada) ● Exceeds IEEE 587 category A & B surge suppression specifications ● $25,000 Ultimate Lifetime Insurance (USA and Canada Only) ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required Specifications 1/4 TLP74R Surge Suppressor 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332155658 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 36000 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 4 Right-Angle Plug No Input Cord Length (m) 1.22 Integrated Cord Clip No OUTPUT Frequency Compatibility 60 Hz Output Receptacles (7) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (4) Yes Outlet Orientation Single row Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 1080 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 400V Automatic Shut-Off Yes 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Gray Housing Color Gray Mounting Holes or Slots No Slot or Hole Mount Measurement (Center to Center) 300 mm Outlets Measurement (Center to Center) 28.5mm Receptacle Color Black Shipping Dimensions (hwd / in.) 2.00 x 4.30 x 14.00 Shipping Dimensions (hwd / cm) 5.08 x 10.92 x 35.56 Shipping Weight (lbs.) 1.10 Shipping Weight (kg) 0.50 Unit Dimensions (hwd / in.) 1.330 x 2.040 x 12.400 Unit Dimensions (hwd / cm) 3.38 x 5.18 x 31.50 Unit Weight (lbs.) 1.04 Unit Weight (kg) 0.47 Input Cord Color Gray FEATURES & SPECIFICATIONS Antimicrobial No Rotatable Outlets No STANDARDS & COMPLIANCE Industry Canada (Communications) No Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; NOM (Mexico); UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Connected Equipment Insurance (U.S., Canada & Puerto Rico) $25,000 Ultimate Lifetime Insurance  © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP74R
物料型号: - 型号:TLP74R
器件简介: - TLP74R提供经济的交流电涌保护,用于保护工作站、台式电脑、电信系统和其他敏感电子设备。内置的交流电涌保护可以防止因瞬态电涌而导致的连接设备损坏和性能问题。TLP74R提供七个总交流电插座(六个直角插座和一个指定的变压器插头插座),4英尺(1.2米)的电源线和诊断LED,以警告保护器损坏。
引脚分配: - 输入:NEMA5-15P插头,14号SJT线,1.22米长 - 输出:7个5-15R插座(6个直角和1个变压器插头插座)
参数特性: - 额定输入电压:120V交流电 - 最大电涌安培:36000 - AC抑制能量等级:1080焦耳 - 自动关闭:是 - 数据线抑制:无 - 网络(以太网)保护:无 - AC抑制响应时间:<1纳秒 - 保护模式:包括全模式(H-N)和共模(N-G / H-G)线路抑制 - UL1449额定通过电压:400V
功能详解: - 提供1080焦耳的交流电涌抑制,保护设备免受强电涌和线路噪声的影响。 - 总共7个交流电插座(6个直角和1个变压器插头插座)。 - 4英尺(1.22米)的交流电线。 - 带集成断路器的照明开关,用于所有插座的过载保护。 - 诊断LED确认电涌抑制状态。 - 集成的钥匙孔插槽提供方便的墙壁/桌面安装。
应用信息: - 适用于保护工作站、台式电脑、电信系统和其他敏感电子设备。
封装信息: - 材料:塑料 - 电源线颜色:灰色 - 外壳颜色:灰色 - 插座颜色:黑色 - 发货尺寸(高宽深/英寸):2.00 x 4.30 x 14.00 - 发货重量(磅):1.10 - 单位尺寸(高宽深/英寸):1.33 x 2.04 x 12.40 - 单位重量(磅):1.04
TLP74R 价格&库存
很抱歉,暂时无法提供与“TLP74R”相匹配的价格&库存,您可以联系我们找货
