TLP606USB
TLP606USB
    TRIPPLITE
    SURGEPROTCTSTRIPUSBOUTLET6'
TLP606USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Protect It! 6-Outlet Surge Protector, 6 ft. (1.83 m) Cord, 990 Joules, 2 x USB Charging ports (2.1A), Gray Housing MODEL NUMBER: TLP606USB Highlights ● 6 outlet / 6-ft. cord ● 990 joule rating ● 2.1 amp dual port USB charger Package Includes Description Tripp Lite's TLP606USB offers economical AC surge suppression for protection of workstations, desktop PCs, telecom systems and other sensitive electronics. Built-in AC surge suppression shields connected equipment from damage and performance problems due to transient surges. USB charging ports offer fast charging for smartphones, tablets, MP3 players and other portable devices. TLP606USB offers 6 total outlets, 6-ft. (1.83 m) cord, 2 USB charging ports and diagnostic LED to warn of suppressor damage. AC suppression rated at 990 joules shields equipment from surges and line noise. Attractive cool grey suppressor housing with keyhole mounting tabs offer convenient protection of desktop computer equipment and accessories. $20,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). PLUG/OUTLETS: Input: NEMA5-15P/Output: 6 NEMA5-15R/6-ft. (1.83 m) AC line cord ELECTRICAL: 120V AC, 50/60Hz, 15A (Requires NEMA5-15R wall receptacle) FORMAT: Corded multi-outlet strip with 1 transformer spaced outlet SUPPRESSION: AC: 150V RMS Clamping/990 joules/400V UL1449 3rd Edition Features ● 6 outlets ● 6-ft. (1.83 m) cord ● 2 USB charging ports - 2.1 amp total ● Surge suppression rating: 990 joules ● EMI/RFI noise filtering ● 15 amp resettable circuit breaker ● Green protection LED ● Includes full normal mode (H-N) and common mode (N-G/H-G) line surge suppression ● Can accommodate 1 large transformer plug without covering remaining outlets, 3 total transformers ● Keyhole support for wall mounting ● Lighted power switch ● $20,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) ● Automatic shutoff permanently cuts power to outlets if protection circuit is incapacitated, preventing equipment damage and indicating replacement is required 1/4 ● TLP606USB surge suppressor ● Instruction manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332180285 Product Type Surge Protector Charging Form Factor Strip Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V (110-125V) Input Cord Gauge Type 14 gauge; SJT Input Cord Gauge (AWG) 14 Voltage Compatibility (VAC) 120 Maximum Surge Amps 35500 Input Plug Type NEMA 5-15P Input Cord Details SJT Input Cord Length (ft.) 6 Right-Angle Plug No Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 15 Overload Protection 15A resettable illuminated combo switch / circuit breaker Transformer Accommodation (2) Yes Outlet Orientation Single row of 6 outlets Right-Angle Outlets No USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and 2 position red illuminated on/off power switch Diagnostic LED Details Built-in LED confirms suppressor "protection present" (green) status 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CHARGING Number of Charging Ports 2 Total Charging Watts 10.5 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports / Amps (2) 2.1A Overcharge Protection No SURGE / NOISE SUPPRESSION AC Suppression Joule Rating 990 AC Suppression Response Time < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line suppression UL1449 Let Through Rating 400V EMI / RFI Filtering Yes Automatic Shut-Off Yes DATALINE SURGE SUPPRESSION Cable (Coax) Protection No Network (Ethernet) Protection No Telephone/DSL Protection No PHYSICAL Material of Construction Plastic Power Cord Color Light Gray Housing Color Light Gray Mounting Holes or Slots Yes Outlets Measurement (Center to Center) 28.5mm Receptacle Color Gray Shipping Dimensions (hwd / in.) 1.90 x 5.70 x 14.70 Shipping Dimensions (hwd / cm) 4.83 x 14.48 x 37.34 Shipping Weight (lbs.) 1.30 Shipping Weight (kg) 0.59 Unit Dimensions (hwd / in.) 1.250 x 1.870 x 13.000 Unit Dimensions (hwd / cm) 3.18 x 4.75 x 33.02 Unit Weight (lbs.) 1.05 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Weight (kg) 0.48 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No GaN Technology No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 269.3 (Canada); CAN/CSA-C22.2 No. 308 (Canada); cUL Listed; UL 1449; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $20,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
TLP606USB
物料型号:TLP606USB 器件简介:TLP606USB 是一款经济型电源防雷器,提供6个交流电源插座和2个USB充电端口,用于保护工作站、桌面电脑、电信系统和其他敏感电子设备。
引脚分配:提供6个5-15R型交流电源插座,2个USB A型充电端口。
参数特性:额定输入电压为120V AC,最大浪涌电流为35,500安培,具有990焦耳的浪涌能量吸收能力,15安培可复位断路器,带有诊断LED指示灯。
功能详解:内置交流浪涌保护功能,可防止瞬态浪涌造成的设备损坏和性能问题。
USB充电端口提供2.1安培的总充电电流,支持快速充电。
外壳颜色为浅灰色,带有挂孔安装槽。
应用信息:适用于需要电源浪涌保护和USB充电功能的场合,如家庭、办公室等。
封装信息:电源线长度为6英尺(1.83米),外壳和电源线颜色为浅灰色,尺寸为1.25 x 1.87 x 13.00英寸(3.18 x 4.75 x 33.02厘米),重量为1.05磅(0.48千克)。
TLP606USB 价格&库存
很抱歉,暂时无法提供与“TLP606USB”相匹配的价格&库存,您可以联系我们找货
