1582T8E1BK
1582T8E1BK
    HAMMONDMANUFACTURING
    RACK MOUNT OUTLET STRIP 10A 8 PO
1582T8E1BK 数据手册
8 7 6 5 4 3 2 1 PILOT LIGHT D D 482.60 mm [19.000 in] 43.64 mm [1.718 in] 145.31 mm [5.721 in] 38.10 mm TYP [1.500 in] 8 X IEC 320 SHEET F OUTLET ISOMETRIC VIEW ASSEMBLY - VIEW FROM FRONT RESETABLE CIRCUIT BREAKER C C 3.50 mm [0.138 in] 67.58 mm [2.661 in] 67.58 mm [2.661 in] 19.05 mm [0.750 in] 40.46 mm [1.593 in] 444.50 mm [17.500 in] ASSEMBLY - VIEW FROM SIDE ASSEMBLY - VIEW FROM BOTTOM B 3.81 mm [0.150 in] B 1582T8E1BK IEC 320 - C14 INLET 10.31 mm [0.406 in] 5.97 mm [0.235 in] 461.98 mm [18.188 in] 31.70 mm [1.248 in] 127.00 mm [5.000 in] A 8 R3.18 mm [0.125 in] ASSEMBLY - VIEW FROM BACK 7 6 5 Finish - Front - Black Painted Steel Back - Black Painted Steel Rated - 230 VAC, 50/60 Hz, 10 Amps Approvals - CSA Certified Standards C22.2 (No. 21-95, 42-99) - cULus Listed Standards UL60950 & CSA C22.2 No. 60950 - TÜV-GS Certified Standard EN60950-1 - CE Certified Registration #: AN 72031916 0001 A 1582T8E1BK 4 3 2 1
1582T8E1BK 价格&库存
很抱歉,暂时无法提供与“1582T8E1BK”相匹配的价格&库存,您可以联系我们找货
