AVBAR6
AVBAR6
    TRIPPLITE
    HOMETHEATERISOBARSURGE6OUT
AVBAR6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Isobar 6-Outlet A/V Surge Protector, 6-ft. Cord, 3330 Joules, Tel/Coax Protection MODEL NUMBER: AVBAR6 Description Tripp Lite’s AVBAR6 Platinum Series Isobar Audio Video Surge / Spike Suppressor provides premium protection (3330 joules) stopping damaging surges and filtering disruptive EMI/RFI line noise so components perform at their peak! You can see and hear the difference: sharper, crisper video; deeper, fuller audio and longer component life spans. Perfect for small-to-medium Audio/Video installations: highdefinition video displays, HD Cable / HD satellite sources and A/V receivers, DVD/CD players and more. Exclusive Isolated Filter Banks eliminate noise interference between components. 6 outlets (widely spaced outlets accommodate up to 2 transformers and plug-in safety covers), 2-line HD 2.2 Ghz coaxial protection and 1-line tel/modem protection safeguard an entire A/V system. $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only). Includes all-metal housing, three diagnostic LEDs (Line OK, Grounded & Protected) and 6-ft. cord with a right-angle plug. Additional accessories include; 6-ft. coaxial cable and 6-ft. phone cord. Features ● 3330 joules surge / spike suppression protection rating ● EMI/RFI line noise filtering help components perform at their peak (sharper, crisper video; deeper, fuller audio and longer component life spans) ● Isolated Filter Banks eliminate interference between connected components ● All-metal housing safely withstands the strongest surges ● 6 surge-protected NEMA 5-15R AC outlets safeguard an Audio / Video system ● $250,000 Ultimate Lifetime Insurance (U.S., Canada, and Puerto Rico only) covers connected components against surge damage...for life! ● Widely spaced outlets accommodate up to 2 transformers ● Four plug-in safety covers protect against accidental contact ● 2 sets of surge-protected Type F gold HD 2.2 GHZ coaxial connectors (with included 6-ft. coaxial cable) safeguard components on cable, satellite or antenna line ● 1-line tel/modem surge protection (with included 6-ft. phone cord) safeguards personal video recorders (Satellite, PVRs) on a single dial-up line. 1/4 Highlights ● 6 outlets / 6-ft. cord with space saving right angle plug ● 3330 joule rating ● Isolated Filter Banks ● 2-line High Definition 2.2 GHz (gold) coaxial surge protection ● 1-line tel/modem surge protection ● All-metal housing 1000 Eaton Boulevard Cleveland, OH 44122 United States ● 6-ft. cord with right-angle NEMA 5-15P plug provides convenient location anywhere within a Audio Video system ● 3 diagnostic LEDs alert user to protection, line power and fault status ● Keyhole slots provide convenient wall or cabinet mounting ● Illuminated master switch provides one-touch power control over all components. Circuit breaker protects against dangerous system overload ● All-metal housing (black) stands up to the most demanding environments ● Tested to UL and cUL, RoHS compliant Specifications OVERVIEW UPC Code 037332144362 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 120V,15A Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Maximum Surge Amps 135000 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 6 Right-Angle Plug Yes Input Cord Length (m) 1.83 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (6) 5-15R Circuit Breaker (amps) 12 Transformer Accommodation (2) Yes Right-Angle Outlets Yes USER INTERFACE, ALERTS & CONTROLS Diagnostic LED(s) Yes Switches Combination AC circuit breaker and illuminated 2-position on/off power switch Diagnostic LED Details Built-in LEDs confirm line power, protection and fault status SURGE / NOISE SUPPRESSION 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States AC Suppression Joule Rating 3330 AC Suppression Response Time NM = instantaneous CM = < 1 ns Protection Modes Includes full normal mode (H-N) and common mode (N-G / H-G) line surge suppression UL1449 Let Through Rating 330V EMI / RFI Filtering Up to 40 dB Automatic Shut-Off No DATALINE SURGE SUPPRESSION Telephone/DSL Protection Details 1 line Cable (Coax) Protection Yes Cable (Coax) Protection Details 2 line (2.2 GHz Bandwidth) Network (Ethernet) Protection No Telephone/DSL Protection Yes PHYSICAL Color Black Material of Construction Metal Power Cord Color Black Housing Color Black Mounting Holes or Slots Yes Slot or Hole Mount Measurement (Center to Center) Distance between horizontal tabs = 210.79mm; Distance between vertical tabs = 58.17mm Outlets Measurement (Center to Center) Distance between horizontal outlets = 39.45mm; Distance between vertical outlets = 39.30mm Receptacle Color Black Shipping Dimensions (hwd / in.) 2.50 x 7.20 x 12.30 Shipping Dimensions (hwd / cm) 6.35 x 18.29 x 31.24 Shipping Weight (lbs.) 3.50 Shipping Weight (kg) 1.59 Unit Dimensions (hwd / in.) 2.500 x 9.000 x 3.500 Unit Dimensions (hwd / cm) 6.35 x 22.86 x 8.89 Unit Weight (lbs.) 2.8 Unit Weight (kg) 1.27 FEATURES & SPECIFICATIONS Rotatable Outlets No Antimicrobial No 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty Connected Equipment Insurance (U.S., Canada & Puerto Rico) $250,000 Ultimate Lifetime Insurance  © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
AVBAR6 价格&库存
很抱歉,暂时无法提供与“AVBAR6”相匹配的价格&库存,您可以联系我们找货
