1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eco-Surge 12-Outlet Home/Business Theater
Surge Protector, 10-ft. Cord, 3600 Joules Accommodates 4 Transformers
Highlights
Auto/manual switch offers
GREEN energy-savings or
standard protection
Unique Netbook Switch allows
user to select wattage
12 outlets / 10-ft cord; 3600
joule rating
2-line 2.2GHz digital gold coax
connectors
1-line tel/modem/network
(100BaseT, high-speed) surge
protection
MODEL NUMBER: AV1210SATG
Package Includes
Description
Tripp Lite's AV1210SATG offers reliable, GREEN surge technology that protects your A/V installations,
the environment and your wallet. This ECO-SURGE offers a unique Netbook switch that allows users to
select wattage, so ECO-SURGE are the only green surge suppressors compatible with all PCs,
Notebooks and Netbooks. Energy-saving outlet configuration reduces energy waste (phantom loads) by
cutting AC power to unused peripherals. The TLP1210SATG offers 3600 joules of advanced surge
protection for all A/V components. You can see and hear the difference: sharper, crisper video; deeper,
fuller audio; longer component life spans. Perfect for small-to-medium home/business theater installations:
high-definition TVs, satellite and A/V receivers, DVD/CD players and more. 12 outlets (with transformer
spacing and sliding safety covers), 2-line 2.2GHz gold coaxial protection and 1-line tel/modem/Ethernet
(100BaseT, high-speed) protection safeguard an entire home/business theater system. Includes two
diagnostic LEDs and four status LED indicators, color-coordinated holographic outlet/plug labels, 10-ft.
cord with a right-angle plug, 6-ft. gold coaxial cable and 6-ft. network cable. $250,000 Ultimate Lifetime
Insurance (U.S., Canada, and Puerto Rico only).
Features
Green Outlet Array; "Master" outlet controls power flow for 1 primary and up to 8 peripheral
components. "Power Save" outlets cut AC power to 8 connected components when not in use - perfect
for non-essential components that do not save settings like DVD players, gaming consoles, amplifiers
and speaker systems. "Always On" outlets provide continuous power to 3 critical devices that save
settings like DVRs and recorders (TiVo), cable and satellite boxes
User-adjustable wattage control switch - allows for high-wattage (over 25W) and low-wattage (over
15W) components to serve as Master device
Auto/Manual Switch - allows users to switch between GREEN (auto) power-save mode and standard
(manual) surge protection
3600 joules surge suppression rating with EMI/RFI line noise filtering help components perform at their
peak (sharper, crisper video; deeper, fuller audio and longer component life spans)
12 widely spaced surge-protected NEMA 5-15R AC outlets safeguard and entire home/business theater
1/4
AV1210SATG ECO-SURGE
Home/Business Theater Surge
Suppressor
6-ft gold coax cable
6-ft network cable
Instruction manual with warranty
information
Cleveland, OH 44122
United States
system while accommodating up to 4 large transformers
Sliding safety covers protect against accidental contact
2 sets of surge-protected 2.2GHz gold coaxial connectors safeguard components on cable, satellite and
antenna line
1-line tel/modem/Ethernet (100BaseT, high-speed) surge protection safeguards personal video
recorders (PVRs) on a single dial-up or Ethernet line. Built-in splitter (1 jack in and 2 jacks out) allows
simultaneous connection of two devices sharing a single line
10-ft. cord with right-angle NEMA 5-15P plug provides convenient location anywhere within a
2 diagnostic LEDs alert user to protection and grounded status and 4 status LEDs indicates when AC
power is present
Keyhole slots provide convenient wall or cabinet mounting
RoHS Compliant
Specifications
OVERVIEW
UPC Code
037332155597
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Input Cord Gauge Type
14 gauge; SJT
Voltage Compatibility (VAC)
120
Maximum Surge Amps
228000
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
10
Right-Angle Plug
Yes
Input Cord Length (m)
3.05
Integrated Cord Clip
No
OUTPUT
Output Capacity (VA)
15
Output Capacity (Watts)
1800
Frequency Compatibility
60 Hz
Output Receptacles
(12) 5-15R
Transformer Accommodation
(8) Yes
Right-Angle Outlets
No
USER INTERFACE, ALERTS & CONTROLS
2/4
Cleveland, OH 44122
United States
Diagnostic LED(s)
Yes
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
3600
AC Suppression Response Time
< 1 ns
Protection Modes
Includes full normal mode (H-N) and common mode (N-G / H-G) line surge suppression
UL1449 Let Through Rating
330, 400, 400
EMI / RFI Filtering
Up to 40 dB
Automatic Shut-Off
Yes
DATALINE SURGE SUPPRESSION
Telephone/DSL Protection Details
1 line
Cable (Coax) Protection
Yes
Cable (Coax) Protection Details
2 line
Network (Ethernet) Protection
Yes
Yes
PHYSICAL
Color
Black
Material of Construction
Plastic
Power Cord Color
Black
Housing Color
Dark Gray
Mounting Holes or Slots
Yes
Slot or Hole Mount Measurement
(Center to Center)
Distance between horizontal tabs = 152mm; Distance between vertical tabs = 73.5mm
Outlets Measurement (Center to
Center)
Distance between standard outlets = 25.4mm; Distance between transformer outlets = 57mm
Receptacle Color
Gray; green
Shipping Dimensions (hwd / in.)
13.60 x 2.00 x 8.80
Shipping Dimensions (hwd / cm)
34.54 x 5.08 x 22.35
Shipping Weight (lbs.)
3.30
Shipping Weight (kg)
1.50
Unit Dimensions (hwd / in.)
1.510 x 4.660 x 12.410
Unit Dimensions (hwd / cm)
3.84 x 11.84 x 31.52
Unit Weight (lbs.)
2.56
Unit Weight (kg)
1.16
FEATURES & SPECIFICATIONS
3/4
Cleveland, OH 44122
United States
Green Energy-Saving Features
Power saving auto-shutoff ECO outlets
Rotatable Outlets
No
Antimicrobial
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
Connected Equipment Insurance
(U.S., Canada & Puerto Rico)
Insurance
© 2023 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
4/4
很抱歉,暂时无法提供与“AV1210SATG”相匹配的价格&库存,您可以联系我们找货
