1583T8E1BK
1583T8E1BK
    HAMMONDMANUFACTURING
    POWER STRIP 19" 10A 230VAC 8OUT
1583T8E1BK 数据手册
8 7 6 5 4 3 2 1 PILOT LIGHT D D 10.31 mm [0.406 in] 5.97 mm [0.235 in] 461.98 mm [18.188 in] R3.18 mm [0.125 in] 31.70 mm [1.248 in] RESETABLE CIRCUIT BREAKER ASSEMBLY - VIEW FROM FRONT ISOMETRIC VIEW 4.57 mm [0.180 in] C C 67.58 mm [2.661 in] 67.58 mm [2.661 in] 40.46 mm [1.593 in] 444.50 mm [17.500 in] 19.05 mm [0.750 in] ASSEMBLY - VIEW FROM BOTTOM 3.81 mm [0.150 in] ASSEMBLY - VIEW FROM SIDE B B IEC 320 - C14 INLET 1583T8E1BK 482.60 mm [19.000 in] 43.64 mm [1.718 in] 38.10 mm [1.500 in] 114.05 mm [4.490 in] A 38.10 mm TYP [1.500 in] 8 X IEC 320 SHEET F OUTLET A ASSEMBLY - VIEW FROM BACK 8 7 6 Finish - Front - Black Painted Steel Back - Black Painted Steel Rated - 230 VAC, 50/60 Hz, 10 Amps Approvals - CSA Certified Standards C22.2 (No. 21-95, 42-99) - cULus Listed Standards UL60950 & CSA C22.2 No. 60950 - TÜV-GS Certified Standard EN60950-1 - CE Certified Registration #: AN 72031916 0001 5 1583T8E1BK 4 3 2 1
1583T8E1BK 价格&库存
很抱歉,暂时无法提供与“1583T8E1BK”相匹配的价格&库存,您可以联系我们找货
1583T8E1BK
  • 1+1384.339701+179.61163
  • 5+936.601265+121.51965
  • 10+886.5053610+115.01994
库存:14
