PS7224
PS7224
    TRIPPLITE
    POWER STRIP 72" 24 OUT 15'COR
PS7224 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 24-Outlet Vertical Power Strip, 120V, 15A, 5-15P, 15 ft. (4.57 m) Cord, 72 in. Highlights ● 24 outlets ● Convenient and safe covered, on/off switch ● 15-amp circuit breaker ● 15-ft. (4.57 m) cord ● 72" length MODEL NUMBER: PS7224 Package Includes Description Tripp Lite's PS7224 power strip offers 15 amp, 120V multi-outlet AC power distribution in a convenient 72 inch mountable housing. Ideal for horizontal or vertical raceway style power distribution in office, workbench, industrial, networking and telecom applications. Includes 24 NEMA 5-15R output receptacles with 2.795 inch center-to-center spacing, 15-ft. (4.57 m) AC line cord and lighted power switch with locking transparent cover to prevent accidental shutoff. Sturdy all-metal extruded aluminum housing stands up to demanding network, laboratory or factory environments. INPUT/OUTPUT: Input: NEMA 5-15P/Output: 24 NEMA 5-15R ELECTRICAL: 120V AC, 50/60Hz, 15A FORMAT: 72 in. corded, mountable power strip Features ● Sturdy all-metal 72 inch corded strip format with 2.795 inch center-to-center outlet spacing ● Included mounting hardware ● Includes 24 NEMA 5-15R output receptacles ● Lighted power switch with locking transparent cover prevents accidental shutoff ● 15 amp electrical capacity with circuit breaker ● 120VAC, 50/60Hz electrical compatibility Specifications OVERVIEW UPC Code 037332011480 INPUT Nominal Input Voltage(s) Supported 120V AC Recommended Electrical Service 15A 120V 1/3 ● PS7224 ● Mounting hardware ● Instruction manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Input Cord Gauge Type 14 gauge; SJT Voltage Compatibility (VAC) 120 Input Plug Type NEMA 5-15P Input Cord Length (ft.) 15 Right-Angle Plug No Input Cord Length (m) 4.57 Integrated Cord Clip No OUTPUT Frequency Compatibility 50 / 60 Hz Output Receptacles (24) 5-15R Circuit Breaker (amps) 15 Transformer Accommodation (12) Yes Right-Angle Outlets No Outlet Spacing 2.795 in. USER INTERFACE, ALERTS & CONTROLS Switches Lighted 2 position switch controls power to all outlets Locking Switch Cover Transparent on/off switch cover prevents accidental turn-off PHYSICAL Color Silver Material of Construction Aluminum Power Cord Color Black Form Factors Supported Supports horizontal or vertical raceway style power distribution in office, workbench, industrial, networking and telecom applications Housing Color Silver Included Mounting Accessories Includes mounting clips Mounting Holes or Slots No Outlets Measurement (Center to Center) 2.83 in. Receptacle Color Black Shipping Dimensions (hwd / in.) 3.00 x 2.00 x 76.00 Shipping Dimensions (hwd / cm) 7.62 x 5.08 x 193.04 Shipping Weight (lbs.) 6.00 Shipping Weight (kg) 2.72 Unit Dimensions (hwd / in.) 1.500 x 1.500 x 72.000 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / cm) 183 x 3.8 x 3.8 Unit Weight (lbs.) 5.5 Unit Weight (kg) 2.49 Outlet Spacing 2.795 in. FEATURES & SPECIFICATIONS Antimicrobial No Built-In Circuit Breaker Yes STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL 1363; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PS7224
物料型号:PS7224
器件简介:PS7224是一款24位垂直电源分配器,提供15A 120V的多插座交流电源分配,外壳为72英寸长的可安装式。
适用于办公室、工作台、工业、网络和电信应用中的水平或垂直布线式电源分配。
包含24个NEMA 5-15R输出插座,2.8英寸的中心距,15英尺(4.6米)交流电源线和带锁定透明盖的照明电源开关,以防止意外关闭。
坚固的全金属挤压铝外壳适用于要求严格的网络、实验室或工厂环境。
引脚分配:包含24个NEMA 5-15R输出插座,插座间距为2.795英寸。
参数特性: - 额定输入电压:120V AC - 推荐电气服务:15A 120V - 输入电源线规格:14号SJT - 电压兼容性(VAC):120 - 输入插头类型:NEMA 5-15P - 输入电源线长度:15英尺(4.57米) - 输出插座:24个5-15R - 电路断路器(安培数):15 - 变压器容量:可适配12个变压器 - 插座间距:2.795英寸
功能详解: - 坚固的全金属72英寸电源条,插座中心距为2.795英寸 - 包含安装硬件 - 24个NEMA 5-15R输出插座 - 带锁定透明盖的照明电源开关,防止意外关闭 - 15安培电气容量,带断路器 - 120VAC,50/60Hz电气兼容性
应用信息:适用于办公室、工作台、工业、网络和电信应用中的水平或垂直布线式电源分配。
封装信息:银色的全金属挤压铝外壳,支持水平或垂直布线式电源分配。
包含安装夹,没有安装孔或插槽。
插座中心距为2.83英寸,插座颜色为黑色。
发货尺寸为3.00x 2.00x76.00英寸,单位尺寸为1.500x1.500x72.000英寸。
单位重量为5.5磅(2.49公斤)。
PS7224 价格&库存
很抱歉,暂时无法提供与“PS7224”相匹配的价格&库存,您可以联系我们找货
