1000 Eaton Boulevard
Cleveland, OH 44122
United States
Eco-Surge 10-Outlet Surge Protector, 8-ft. Swivel
Cord, 6480 Joules, Tel/Modem/Coax/Ethernet
Protection
MODEL NUMBER: AV10IRG
Highlights
6,480 joules of advanced surge
protection for medium-to-large
home/business theater
installations
10 outlets, 3-line coaxial and 1line tel/network protection
8-ft. swivel cord, 6-ft. coaxial
cable and 6-ft. network cable
ECO-SURGE feature saves
energy by disabling AC power to
unused POWER SAVE outlets
Package Includes
Description
Do you need a quality surge protection for equipment in your home/business theater such as high
definition TVs, satellite A/V receivers, DVD/CD players, DVR/Tivo recorders, and has energy-saving
capabilities as well? Then Tripp Lite's AV10IRG ECO-Surge Suppressor featuring reliable, power-saving,
GREEN surge technology is a great choice. The AV10IRG offers 6,480 joules of advanced surge
protection. You will see and hear the difference: sharper, crisper video; deeper, fuller audio; longer
component life spans. It can safeguard your entire home theater system in a robust 10-outlet, 3-line 2.2
GHz digital gold coaxial protection and 1-line tel/network protection package; it also includes 3 diagnostic
LEDs, 4 status LEDs, an 8-ft. swivel cord, a 6-ft. coaxial cable and a 6-ft. network cable. To save energy,
the AV10IRG is designed with an energy-saving outlet configuration that reduces energy waste (phantom
loads) by cutting AC power to unused peripherals. To enable the GREEN "Power Save" outlets, the
AV10IRG has an IR receiver embedded in its front panel that can receive a turn-on signal from any IR
remote. The AV10IRG has a sleek, contemporary design, and a LCD screen that fits into any A/V
installation. For peace of mind, the AV10IRG comes with $250,000 Ultimate Lifetime Insurance coverage
(U.S., Canada, and Puerto Rico only).
Features
Premium Level of Surge Protection
● 6,480-joule surge suppression rating with EMI/RFI line noise filtering to help components perform at
their peak (i.e. sharper, crisper video; deeper, fuller audio and longer component life spans)
1-line of tel/modem/Ethernet (100BaseT, high-speed) surge protection safeguards personal video
recorders (PVRs) on a single dial-up or Ethernet line.
3-lines of surge-protected, 2.2 GHz gold coaxial connectors to safeguard devices on cable, satellite and
antenna lines
Extra Long Power Cord
1/4
AV10IRG ECO-SURGE Energy
Saving Surge Suppressor
6-ft. tel/network cable
6-ft. gold coaxial cable
Cleveland, OH 44122
United States
8-ft, NEMA 5-15P, swivel power cord reaches around corners, obstacles or can access distant outlets
NEMA-Rated, Protected Outlets
● 10 rear-facing, NEMA 5-15R, surge-protected outlets (7 ECO-SURGE protected and 3 ALWAYS ON
protected)
Diagnostic LED Indicators
● 3 diagnostic LEDs to alert users to the power, protection and safety-ground status
4 status LEDs to indicate when AC power is present.
An illuminated LED panel shows real time amperage readings of the 7 "Power Save" outlets, helping to
avoid power overloads
ECO-Surge Technology
● ECO-Surge, "Power Save" Green Outlet Array switches off AC power approximately 3 minutes after the
internal GREEN “Power Save” technology detects the total power consumption of the “Power Save”
outlets has dropped 70%. “Power Save” outlets are recommended for intermittent-use devices such as
TVs, receivers, monitors, printers, scanners, lamps, DVD players, gaming consoles, amplifiers and
speaker systems
“Always On” outlets provide continuous power even after the “Power Save” outlets are turned OFF.
These outlets are recommended for 3 critical devices that save settings such as DVRs and recorders
(TiVo), cable and satellite boxes
IR receiver receives a turn-on signal from any standard IR remote to energize devices plugged into the
IR extension jack works with an optional cord and small receiver to extend IR transmission distance.IR
Extender Referral Link
Specifications
OVERVIEW
UPC Code
037332155627
INPUT
Nominal Input Voltage(s) Supported
120V AC
Recommended Electrical Service
120V (110-125V)
Plug Type
NEMA-P
Input Cord Gauge Type
14 gauge; SJT
Voltage Compatibility (VAC)
120
Maximum Surge Amps
432000
Input Plug Type
NEMA 5-15P
Input Cord Length (ft.)
8
Right-Angle Plug
No
Input Cord Length (m)
2.44
Integrated Cord Clip
No
2/4
Cleveland, OH 44122
United States
OUTPUT
Frequency Compatibility
60 Hz
Output Receptacles
(10) 5-15R
Outlet Orientation
10 rear outlets (7 controlled, 3 unswitched)
USER INTERFACE, ALERTS & CONTROLS
Diagnostic LED(s)
Yes
SURGE / NOISE SUPPRESSION
AC Suppression Joule Rating
6480
AC Suppression Response Time
