PDUV15
PDUV15
    TRIPPLITE
    PDU BASIC 15A 5-15R 14 OUTLET
PDUV15 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.4kW Single-Phase 120V Basic PDU, 14 NEMA 515R Outlets, NEMA 5-15P Input, 15 ft. (4.57 m) Cord, 0U Vertical MODEL NUMBER: PDUV15 Highlights ● NEMA 5-15P input with 15-ft. (4.57 m) cord ● 14 NEMA 5-15R outlets ● Switchless design prevents accidental shutdown ● 36 in. all-metal housing ● Supports toolless 0U vertical mounting Package Includes Delivers 120V single-phase AC power to multiple loads from a utility outlet, generator or UPS system in a high-density IT environment. Recommended for data centers, server rooms and network wiring closets. Description The PDUV15 1.44kW Single-Phase 120V Basic PDU is an excellent no-frills unit for data centers, server rooms and network wiring closets. Perfectly suited for high-density IT environments, the PDUV15 features 14 NEMA 5-15R outlets. The NEMA 5-15P input plug with long 15-ft. (4.57 m) cord connects to your facility's compatible AC power source, generator or protected UPS to distribute power to connected equipment. The switchless design prevents an accidental shutdown, which could lead to costly downtime. A 15A circuit breaker protects connected equipment from dangerous overloads. The 36-inch all-metal housing supports 0U vertical mounting in EIA-standard 19-inch racks using the included hardware and mounting clips or toolless mounting using the included buttons. You can also mount the PDUV15 on a wall or workbench or under a counter with user-supplied hardware. Features Reliable Single-Phase Power Distribution ● Versatile no-frills PDU for data centers, server rooms and network wiring closets ● 14 NEMA 5-15R outlets ● NEMA 5-15P input with 15-ft. (4.57 m) cord ● 15A circuit breaker protects outlets against overloads Switchless Design ● Prevents accidental shutdowns and costly downtime Versatile Installation Options ● 36 in. all-metal housing ● Supports toolless 0U vertical mounting in EIA-standard 19 in. racks ● Also supports 0U mounting using included hardware ● Rear installation buttons can be relocated to the left or right surface for rear, center or forward-facing 1/3 ● PDUV15 1.44kW Single-Phase 120V Basic PDU ● Mounting brackets ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States outlet orientation ● Also mounts on wall, workbench or under a counter with user-supplied hardware Specifications OVERVIEW UPC Code 037332144515 PDU Type Basic INPUT PDU Input Voltage 120 Recommended Electrical Service Single-phase 15A 120V service Maximum Input Amps 12 Maximum Input Amps Details Agency de-rated to 12A continuous PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 1.44kW (120V) / 12A total capacity; 12A max per 5-15R outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (14) 5-15R Output Nominal Voltage 120V Overload Protection 15A circuit breaker SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported Vertical (0U) mounting in rack enclosures, horizontal mount in raceways and a variety of other applications PDU Form Factor Vertical (0U) Shipping Dimensions (hwd / in.) 39.76 x 3.62 x 2.40 Shipping Dimensions (hwd / cm) 100.99 x 9.19 x 6.10 Shipping Weight (lbs.) 4.00 Shipping Weight (kg) 1.81 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Unit Dimensions (hwd / in.) 1.750 x 36.000 x 1.250 Unit Dimensions (hwd / cm) 92.63 x 3.81 x 4.17 Unit Weight (lbs.) 3.61 Unit Weight (kg) 1.64 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUV15 价格&库存
很抱歉,暂时无法提供与“PDUV15”相匹配的价格&库存,您可以联系我们找货
