PDUMH15-6
PDUMH15-6
    TRIPPLITE
    POWER STRIP 13OUT RACK AMMETER
PDUMH15-6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.5kW Single-Phase Local Metered PDU, 100127V Outlets (13 5-15R), 5-15P Input with 6 ft. (1.83 m) Cord, 1U Rack-Mount MODEL NUMBER: PDUMH15-6 Highlights ● Local metered single phase 12A 100-127V PDU ● 1U horizontal rackmount, Digital current meter ● NEMA 5-15P input with 6ft / 1.8m line cord ● 13 NEMA 5-15R outlets (1 front / 12 rear) ● Reversible housing, 4.5 in / 11.4cm depth Package Includes Features ● 15A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 12A continuous) ● Built-in 2 digit visual meter continuously reports PDU load level in amps ● Attached NEMA 5-15P 15A 120V input plug with 6 ft. / 1.8m line cord ● 1U horizontal rackmount format installs in one rack space ● 13 NEMA 5-15R outlets (1 front facing / 12 rear) ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Optional PDUSIDEBRKT enables 0U vertical rackmount in compatible racks ● Back panel grounding lug Specifications OVERVIEW UPC Code 037332182883 PDU Type Local Metered INPUT PDU Input Voltage 100; 120; 125; 127 Recommended Electrical Service Single-phase 15A 100-127V service Maximum Input Amps 12 1/3 ● PDUMH15-6 Local Metered rackmount PDU ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 12A continuous PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 6 Input Cord Length (m) 1.83 OUTPUT Output Capacity Details 1.52kW (127V), 1.44kW (120V), 1.2kW (100V) / 12A total capacity); 12A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (13) 5-15R Output Nominal Voltage 100-127V Overload Protection 15A circuit breaker USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 19.05 Minimum Required Rack Depth (inches) 7.5 Outlets Measurement (Center to Center) Rear Side = 30.20mm PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.40 x 9.30 x 20.60 Shipping Dimensions (hwd / cm) 6.10 x 23.62 x 52.32 Shipping Weight (lbs.) 4.30 Shipping Weight (kg) 1.95 Unit Dimensions (hwd / in.) 1.750 x 17.300 x 3.750 Unit Dimensions (hwd / cm) 4.45 x 44.45 x 11.43 Unit Weight (lbs.) 4.5 Unit Weight (kg) 2.04 ENVIRONMENTAL 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Rear grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH15-6 价格&库存
很抱歉,暂时无法提供与“PDUMH15-6”相匹配的价格&库存,您可以联系我们找货
