PDUMH15-RA
PDUMH15-RA
    TRIPPLITE
    PDU SWITCHED 120V 15A 8 OUTLET
PDUMH15-RA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 1.5kW Single-Phase Local Metered PDU, 100127V Outlets (13 5-15R), 5-15P, 100-127V Input, 15 ft. (4.57 m) Cord, 1U Rack-Mount MODEL NUMBER: PDUMH15-RA Highlights ● Local metered single phase 12A 100-127V PDU ● 1U horizontal rackmount, Digital current meter ● NEMA 5-15P input with 15-ft. (4.57 m) line cord ● 13 NEMA 5-15R outlets oriented with ground pin on the bottom (1 front / 12 rear) ● Reversible housing 4.5 in / 11.4cm depth Package Includes Features ● 15A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 12A continuous) ● Built-in 2 digit visual meter continuously reports PDU load level in amps ● Attached NEMA 5-15P 15A 100-120V input plug with 15-ft. (4.57 m) line cord ● 1U horizontal rackmount format installs in one rack space ● 13 NEMA 5-15R outlets oriented with the ground pin on the bottom (1 front facing / 12 rear) ● Mounting flanges support installation in 2 and 4 post racks, with additional support for wall-mount and under-counter installation formats ● Optional PDUSIDEBRKT enables 0U vertical rackmount in compatible racks ● Back panel grounding lug Specifications OVERVIEW UPC Code 037332183231 PDU Type Local Metered INPUT PDU Input Voltage 100; 120; 125; 127 Recommended Electrical Service Single-phase 15A 100-127V service Maximum Input Amps 12 1/3 ● PDUMH15-RA Local Metered rackmount PDU ● Owner's manual with warranty information 1000 Eaton Boulevard Cleveland, OH 44122 United States Maximum Input Amps Details Agency de-rated to 12A continuous PDU Plug Type NEMA 5-15P Input Phase Single-Phase Input Cord Length (ft.) 15 Input Cord Length (m) 4.57 OUTPUT Output Capacity Details 1.52kW (127V), 1.44kW (120V), 1.2kW (100V) / 12A total capacity; 12A max per outlet Frequency Compatibility 50 / 60 Hz Output Receptacles (13) 5-15R Output Nominal Voltage 100-127V Overload Protection 15A circuit breaker USER INTERFACE, ALERTS & CONTROLS Front Panel LCD Display Digital display reports total PDU output current in amps SURGE / NOISE SUPPRESSION Automatic Shut-Off No PHYSICAL Material of Construction Metal Form Factors Supported 1U rackmount, 0U vertical rackmount, wall-mount, and under-counter installation Minimum Required Rack Depth (cm) 17.27 Minimum Required Rack Depth (inches) 6.8 PDU Form Factor Horizontal (1U) Shipping Dimensions (hwd / in.) 2.25 x 20.50 x 10.00 Shipping Dimensions (hwd / cm) 5.72 x 52.07 x 25.40 Shipping Weight (lbs.) 5.20 Shipping Weight (kg) 2.36 Unit Dimensions (hwd / in.) 1.750 x 17.300 x 3.750 Unit Dimensions (hwd / cm) 4.45 x 44.45 x 9.5 Unit Weight (lbs.) 4.6 Unit Weight (kg) 2.09 ENVIRONMENTAL Operating Temperature Range 0C ~ 40C (32F ~ 104F) Storage Temperature Range -30°C to +50°C (-22°F to +122°F) 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Relative Humidity 5-95% non-condensing Operating Elevation (ft.) 0-10,000 Operating Elevation (m) 0-3000 FEATURES & SPECIFICATIONS TVSS Grounding Rear grounding lug STANDARDS & COMPLIANCE Product Certifications RETIE (Colombia); NOM (Mexico); UL 60950-1 Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
PDUMH15-RA
物料型号: - 型号:PDUMH15-RA
器件简介: - Tripp Lite系列的1.5kW单相本地计量PDU,具有100-127V输入,15英尺(4.57米)电源线,1U机架安装。
引脚分配: - 13个NEMA 5-15R插座,其中1个前置,12个后置,且地线针在底部。
参数特性: - 输入电压:100V、120V、125V、127V - 推荐电气服务:单相15A 100-127V服务 - 最大输入安培:12A(连续) - 输出容量:1.52kW(127V)、1.44kW(120V)、1.2kW(100V)/ 12A总容量;每个插座最大12A - 频率兼容性:50/60 Hz - 输出插座:13个5-15R - 输出额定电压:100-127V - 过载保护:15A电路断路器
功能详解: - 15A单相100-127V本地计量电源分配单元(PDU) - 内置2位数字电流表,持续报告PDU负载水平(安培) - 附带NEMA 5-15P 15A 100-120V输入插头和15英尺(4.57米)电源线 - 1U水平机架安装格式,安装在一个机架空间内 - 可支持2柱和4柱机架安装,额外支持墙挂和台下安装 - 可选PDUSIDEBRKT实现0U垂直机架安装
应用信息: - 适用于需要本地计量和电源分配的单相应用场景。
封装信息: - 材料:金属 - 机架高度:1U - 支持的安装形式:1U机架安装、0U垂直机架安装、墙挂和台下安装 - 最小所需机架深度:17.27厘米(6.8英寸) - PDU形式因素:水平(1U) - 发货尺寸:2.25x20.50x10.00英寸(5.72x52.07x25.40厘米) - 发货重量:5.20磅(2.36千克) - 单位尺寸:1.750x17.300x3.750英寸(4.45x44.45x9.5厘米) - 单位重量:4.6磅(2.09千克)
PDUMH15-RA 价格&库存
很抱歉,暂时无法提供与“PDUMH15-RA”相匹配的价格&库存,您可以联系我们找货
