ZAP Traps
ZT Series
Key Features
Outlet Strips with Surge Protection
22
• Five stages of protection.
• Protection in all three AC modes and diagnostic monitoring with 3 LEDs.
• Red LED fault indicator identifying power outlet problems of open or poor grounding, line
neutral reversal, excessive ground to neutral.
• Available with or without (see tables below) long-life superior telco-protection circuit.
Single line circuit featuring delta protection with three long life semiconductor suppressors.
Components FCC part 68 rated to 175 amps clamping at 145V, crowbar at 180V and fused to
isolate sustained faults.
• Heavy 14 gauge 6’ wire cord.
• Mounting feet (with keyhole slots) allow temporary work station mounting if desired.
• 14/3 SJT or SJTW cord for extreme temperature ranges and integral molded plug.
• Rugged aluminum housing, 15 amp resettable breaker, available in 4, 6 or 8 AC receptacle
models, on/off switch.
• Self-healing gas discharge tube protection rated at a minimum of 2,000 joules! Crowbar
primary protection to 30,000 amps for sustained faults.
• 24,000 amps maximum transient current.
• Response time of less than 1 nanosecond.
• Voltage suppression at the outlet guards against transients from equipment on the power bar.
• CSA certified, Standards C22.2 (No. 21-95, No. 42-99 and No. 8-M1986)
Part No.
Outlets
ZT1001-4
ZT1001-6
ZT1001-8
ZT2001-4
ZT2001
ZT2001-8
4
6
8
4
6
8
EMI/RFI
Min. Noise
Attenuation
80 db
80 db
80 db
80 db
80 db
80 db
Diagnostics Telco Protection
Yes
Yes
Yes
Yes
Yes
Yes
www.hammondmfg.com
No
No
No
Yes
Yes
Yes
很抱歉,暂时无法提供与“ZT2001”相匹配的价格&库存,您可以联系我们找货
