1000 Eaton Boulevard
Cleveland, OH 44122
United States
1.5kW Single-Phase Local Metered PDU, 100127V Outlets (14 5-15R), 5-15P, 15 ft. (4.57 m)
Cord, 0U Vertical, 36 in.
Highlights
Local Metered single phase 12A
100-127V 0U 36in / 91cm
vertical rackmount PDU
Two-digit current meter reports
output current in amps
Attached 15-ft. (4.57 m) cord
with NEMA 5-15P input plug
14 NEMA 5-15R outlets
Toolless button mount and boltdown bracket installation
hardware included
MODEL NUMBER: PDUMV15-36
Package Includes
Features
12A single phase 100-127V Local Metered Power Distribution Unit / PDU (Agency de-rated to 12A
continuous)
Two-digit lighted meter reports combined total output current in amps
Attached NEMA 5-15P 15A 100-127V input plug with 15-ft. (4.57 m) line cord
0U 36in / 91cm vertical rackmount format installs using no rack spaces
Includes 15A circuit breaker and lighted power switch inside a transparent protective cover
Toolless installation supported in button-mount compatible equipment racks
Bolt-down installation brackets support installation in other racks and additional surfaces
Specifications
OVERVIEW
UPC Code
037332182869
PDU Type
Local Metered
INPUT
PDU Input Voltage
100; 120; 125; 127
Recommended Electrical Service
Single-phase 15A 100-127V service
Maximum Input Amps
12
Maximum Input Amps Details
Agency de-rated to 12A continuous
1/3
Local Metered Vertical PDU
Mounting hardware and spare
mounting buttons
Owner's manual with warranty
information
Cleveland, OH 44122
United States
PDU Plug Type
NEMA 5-15P
Input Phase
Single-Phase
Input Cord Length (ft.)
15
Input Cord Length (m)
4.57
OUTPUT
Output Capacity Details
1.52kW (127V), 1.44kW (120V), 1.2kW (100V) / 12A total capacity; 12A max per outlet
Frequency Compatibility
50 / 60 Hz
Output Receptacles
(14) 5-15R
Output Nominal Voltage
100-127V
Overload Protection
15A circuit breaker
USER INTERFACE, ALERTS & CONTROLS
Front Panel LCD Display
Digital meter reports PDU output current in amps
Switches
Lighted on/off switch with integrated safety cover
SURGE / NOISE SUPPRESSION
Automatic Shut-Off
No
PHYSICAL
Material of Construction
Aluminum
Form Factors Supported
Vertical (0U) mounting in rack enclosures, horziontal mount in raceways and a variety of other applications
PDU Form Factor
Vertical (0U)
Shipping Dimensions (hwd / in.)
2.21 x 38.93 x 5.56
Shipping Dimensions (hwd / cm)
5.61 x 98.88 x 14.12
Shipping Weight (lbs.)
3.79
Shipping Weight (kg)
1.72
Unit Dimensions (hwd / in.)
36.000 x 1.750 x 1.250
Unit Dimensions (hwd / cm)
91.4 x 4.45 x 3.2
Unit Weight (lbs.)
3.2
Unit Weight (kg)
1.45
ENVIRONMENTAL
Operating Temperature Range
0C ~ 40C (32F ~ 104F)
Storage Temperature Range
-30°C to +50°C (-22°F to +122°F)
Relative Humidity
5-95% non-condensing
Operating Elevation (ft.)
0-10,000
2/3
Cleveland, OH 44122
United States
Operating Elevation (m)
0-3000
STANDARDS & COMPLIANCE
Product Certifications
RETIE (Colombia); CAN/CSA-C22.2 No. 60950-1 (Canada); NOM (Mexico); UL 60950-1
Product Compliance
RoHS; FCC Part 15 Class A (USA)
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
2-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“PDUMV15-36”相匹配的价格&库存,您可以联系我们找货
